Trying to install hotspot package
I have a level 4 liscence that has 200 user limit on hot spot. When I try to add the 2.9.23 package hotspot-2.9.23.npkI get this error message.
“could not change the key - invalid key”.
My router has 2.9.23 packages installed right now. I even tried to add one of the ones I allready have and get the same message. Whats happening. Is my key corrupt???
I thought level 4 liscence had a 200 user hotspot ability???
Travis
tcpip77,
Check ‘system package print’, what packages you have installed now.
If there is no HotSpot package,
run any FTP client connecting to the router, upload hotspot package.
To enable package ‘system package enable hotspot’ and reboot router.
I can drag and drop the packages but I get the error messages. The FTP worked though. How can I re-enable the drag and dropping so that I dont have to fire up FTP all the time?
I used to be able to just drag a package onto the system | packages window. Now I get that key error. How can I fix it?
Travis
Umm.. Never mind Im an idiot. You dont drag and drop on system - packages you drag and drop them into the files listing and then reboot. Sorry… its 2:30 am and Im tired.
Travis
Thanks for the help : ) :blush:
