Trying to install the Router OS at IoT product
Hi all. I am a beginner.
I am now trying to install the Router OS into an IoT product.
But this is not x86 platform. It is NXP I.MX8.
Is there any possibility to install and run the OS.
The product can support Linux Yocto OS and Ubuntu.
Install an x86 emulator on Linux and use RouterOS CHR instead of RouterOS x86
What are you trying to accomplish?
If you are wanting a useable experience, using it through an emulator on a slow CPU will not net you anything worth using. If you are wanting to learn about Router OS and how to use its functions, I would recommend GNS3 or EVE-NG with the CHR images.
