Trying to make 2 isp please help
Please give advice what to do more with my router.. Im very new to mikrotik and im not sure if this configuration is correct and will work fine.. please give any suggestions.. thank you.
add name=bridge1
set [ find default-name=ether1 ] name=WAN1
set [ find default-name=ether2 ] name=WAN2
add name=WAN
add name=LAN
add name=dhcp_pool0 ranges=192.168.33.2-192.168.33.254
add address-pool=dhcp_pool0 disabled=no interface=bridge1 name=dhcp1
/queue simple
add name=WAN1 target=192.168.1.0/24
add name=WAN2 target=192.168.2.0/24
add name=bridge1 target=192.168.33.0/24
/tool user-manager customer
set admin access=\
    own-routers,own-users,own-profiles,own-limits,config-payment-gw
add interface=WAN1 list=WAN
add address=192.168.1.2/24 interface=WAN1 network=192.168.1.0
add address=192.168.2.251/24 interface=WAN2 network=192.168.2.0
add address=192.168.33.1/24 interface=bridge1 network=192.168.33.0
add address=192.168.33.0/24 gateway=192.168.33.1
set servers=8.8.8.8,8.8.4.4
/ip firewall mangle
add action=mark-connection chain=input in-interface=WAN1 new-connection-mark=\
    WAN1 passthrough=yes
add action=mark-connection chain=input in-interface=WAN2 new-connection-mark=\
    WAN2 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN1 new-routing-mark=\
add action=mark-routing chain=output connection-mark=WAN2 new-routing-mark=\
add action=masquerade chain=srcnat src-address=192.168.33.0/24
add action=masquerade chain=srcnat out-interface=WAN1
add action=masquerade chain=srcnat out-interface=WAN2
add distance=1 gateway=192.168.1.1 routing-mark=WAN1
add distance=1 gateway=192.168.2.1 routing-mark=WAN2
add check-gateway=ping distance=1 gateway=192.168.1.1,192.168.2.1
