trying to peer into network using OSPF
Afternoon
i need a little help trying to peer into a network that is attached to an ospf network without using masquerade.
I’ll first start by giving you some exports of router that this all needs to take place from.
 #     NAME                                        TYPE             MTU   L2MTU
 0  R  ether3                                      ether            1500  1600
 1  R  ether1                                      ether            1500  1600
 2  R  ether2                                      ether            1500  1600
 3  R  Hunters                                     wlan             1500  2290
 4  R  Belvidere                                   wlan             1500  2290
 5  X  anthony                                     wlan             1500
 6  R  Omni                                        wlan             1500  2290
 7  R  Stadium                                     wlan             1500  2290
Ether 1 heads to the core router that supplies internet to the network. ether 2 is the main office. ether 3 is where this peering needs to happen, it connects directly to a radius server.
 #   ADDRESS            NETWORK         BROADCAST       INTERFACE
 1   192.168.252.1/24   192.168.252.0   192.168.252.255 ether2
 3   192.168.100.2/30   192.168.100.0   192.168.100.3   ether1
**note: i am only showing you the IPs pertaining to the ether ports
AS you can see only ether 1 and 2 have IP addresses. when i just could not look back into ether 3 without masquerade i setup a PPP on the server. it work halfway.
 0   chain=srcnat action=masquerade out-interface=ether1
 1   chain=srcnat action=masquerade out-interface=ether2
as you can see masquerade is running on ether 1 and 2. it cannot run on ether 3 or the radius server will not know from where the requests came from but without the masquerade i can’t even ping the server.
i need to be able to peer the server from anywhere on the network without putting masquerade on the ether port it connects to.
Can anyone help me with this
Apply an IP address to a port, put the server behind it, add that network and interface to the OSPF process.
sorry, i’m not very clued up with OSPF
Could you explain to me how to go about that please
Add an IP address to an interface as you usually would. That will form the default gateway for the network the server will be on, and the network that will be advertised via OSPF.
Then add the network to OSPF: http://wiki.mikrotik.com/wiki/Manual:Routing/OSPF#Network. You can emulate the other networks already in OSPF on that router.
That go to the OSPF interfaces: http://wiki.mikrotik.com/wiki/Manual:Routing/OSPF#Interface. Add the interface the network you just added is on is and set its ‘passive’ parameter to ‘yes’.
Then check that the network is being seen by other routers in the OSPF domain.
If you’re going to run OSPF it’s worth learning about it. It’s not as trivial as some other routing protocols. Waiting until you have to troubleshoot it because there’s an issue is a bad time to learn - Cisco and Juniper have excellent, free, on-line documentation that includes OSPF. It’s aimed at their platforms but is still going to explain the concepts fairly well.
I never setup this OSPF, it was done by our previous network admin. when he left i was forced to have to fill his shoes which is not easy.
I have a book called basic routing with seems to cover the theory of OSPF but it does help me with the practical use and my CCNA coarse hardly even goes over it.
Any ways.
I have done what you told me but right now i’m getting a small issue. from the directly connected router i can ping the server but not from anywhere else.
I’m gonna give you a snap shot of the OSPf from the connected router and then one sitting at the end of the network
Connected router
 #   NETWORK            AREA
 0   0.0.0.0/0          backbone
 1   192.168.253.0/24   backbone
the second i put in, the first was placed by our old admin
173 192.168.253.0/24   intra-area     10           0.0.0.0         ether3     >
Pulled this our of the OSPF routes table, this is what the connected tower is seeing
Flags: X - disabled
 0   name="default" router-id=192.168.100.126 distribute-default=never
     redistribute-connected=no redistribute-static=as-type-2
     redistribute-rip=no redistribute-bgp=no redistribute-other-ospf=no
     metric-default=1 metric-connected=20 metric-static=20 metric-rip=20
     metric-bgp=auto metric-other-ospf=auto in-filter=ospf-in
     out-filter=ospf-out
And now a far end router
 #   NETWORK            AREA
 0   192.168.0.0/16     backbone
175 192.168.253.0/24   intra-area     80           192.168.100.5   ether2     >
Again, pulled this route out of the route table
Flags: X - disabled
 0   name="default" router-id=192.168.100.6 distribute-default=never
     metric-bgp=20 metric-other-ospf=auto in-filter=ospf-in
     out-filter=ospf-out
everything was done by our network admin, the only change i have done is adding that 192.168.253.0/24 network on the connecting tower as well as the interface. basically what you told me to add.
If you need any more info please ask
right. been doing a little testing. it turns out the reason the ping test on the connected router could ping the Radius server was because it was performing pings out of the connected interface. if i tried to from from a different network which is sitting on a different interface the ping fails
192.168.253.8 > server
this ping fails
however pinging the interface itself does receive an echo
192.168.253.1 > interface
this one responds
I’m gonna add an export of the OSPF interfaces
Flags: X - disabled, I - inactive, D - dynamic, P - passive
 #    INTERFACE                COST  PRI NETWORK-TYPE   AUT... AUTHENTICATIO...
 0  P ether3                   10    1   broadcast      none
 1 D  Hunters                  10    1   broadcast      none
 2 D  Belvidere                10    1   broadcast      none
 3 D  <pppoe-janie>            10    1   point-to-point none
 4 D  ether1                   10    1   broadcast      none
 5 D  <pppoe-seanetadmin-1>    10    1   point-to-point none
 6 D  <pppoe-katt>             10    1   point-to-point none
 7 D  ether2                   10    1   broadcast      none
 8 D  Stadium                  10    1   broadcast      none
 9 D  <pppoe-radius-1>         10    1   point-to-point none
According to that other towers have a route to that network, as they should. Are you sure you’re not duplicating IP space and that the network you’re introducing isn’t somewhere else already? This could also be as simple as the server not having the correct default gateway configured so it can’t talk to anyone that is not directly connected. Or its firewall being configured to only allow ping from directly connected networks, this happens a lot with recent versions of Windows.
Please post the following from the directly connected router:
“/interface print detail”, “/ip address print detail”, “/ip route print detail”, “/routing ospf export”, and “/routing ospf lsa print detail”. Include the line of the ccommand being run in what you copy/paste so that it’s easy to figure out the router name and exact command syntax that led to the output. Also post a network diagram.
Also, and I am not saying that to make you feel bad or anything, but if you inherited a network with OSPF then it’s time to hunker down and study OSPF. You cannot administrate a network where you cannot predict packet paths because you don’t know the routing protocol being used inside out. Sooner or later that will lead to very not fun nights troubleshooting.
i am trying to learn but the books i have on the subject talk about the protocol, its theory but when i try take that to the practical stage it just doesn’t want to work right :frowning:
I have some virtual machines at home (i’d have them here at work if the machine i worked on was powerful enough to run multiple virtual machines) running RouterOS and even there i can’t get it working right. that basically tells me, despite me having read through those books a few times trying to understand it, there must be something very simple that i’m just not seeing.
anyways, onto the print outs
Warning, prepare for a wall of text 0.o
 0  R  name="ether3" type="ether" mtu=1500 l2mtu=1600
 1  R  name="ether1" type="ether" mtu=1500 l2mtu=1600
 2  R  name="ether2" type="ether" mtu=1500 l2mtu=1600
 3  R  name="Hunters" type="wlan" mtu=1500 l2mtu=2290
 4  R  name="Belvidere" type="wlan" mtu=1500 l2mtu=2290
 5  X  name="anthony" type="wlan" mtu=1500
 6  R  name="Omni" type="wlan" mtu=1500 l2mtu=2290
 7  R  name="Stadium" type="wlan" mtu=1500 l2mtu=2290
 8 DR  name="<pppoe-janie>" type="pppoe-in" mtu=1480
 9 DR  name="<pppoe-radius-1>" type="pppoe-in" mtu=1480
10 DR  name="<pppoe-katt>" type="pppoe-in" mtu=1480
 0   address=192.168.100.126/30 network=192.168.100.124 broadcast=192.168.100.127 interface=Hunters actual-interface=Hunters
 1   address=192.168.252.1/24 network=192.168.252.0 broadcast=192.168.252.255 interface=ether2 actual-interface=ether2
 2   address=192.168.100.153/30 network=192.168.100.152 broadcast=192.168.100.155 interface=Belvidere actual-interface=Belvidere
 3   address=192.168.100.2/30 network=192.168.100.0 broadcast=192.168.100.3 interface=ether1 actual-interface=ether1
 4   address=192.168.100.201/30 network=192.168.100.200 broadcast=192.168.100.203 interface=Stadium actual-interface=Stadium
 5 D address=192.168.104.223/32 network=192.168.104.220 broadcast=0.0.0.0 interface=<pppoe-janie> actual-interface=<pppoe-janie>
 6   address=192.168.253.1/24 network=192.168.253.0 broadcast=192.168.253.255 interface=ether3 actual-interface=ether3
 7 D address=192.168.140.1/32 network=192.168.140.2 broadcast=0.0.0.0 interface=<pppoe-radius-1> actual-interface=<pppoe-radius-1>
 8 D address=192.168.104.176/32 network=192.168.104.172 broadcast=0.0.0.0 interface=<pppoe-katt> actual-interface=<pppoe-katt>
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 0 A S  dst-address=0.0.0.0/0 gateway=192.168.100.1 gateway-status=192.168.100.1 reachable ether1 distance=1 scope=30 target-scope=10
 1 ADo  dst-address=10.5.50.0/24 gateway=192.168.100.202 gateway-status=192.168.100.202 reachable Stadium distance=110 scope=20 target-scope=10 ospf-metric=20 ospf-type=intra-area
 2 ADo  dst-address=10.5.51.0/24 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70 ospf-type=intra-area
 3 A S  dst-address=192.168.0.0/24 gateway=192.168.100.1 gateway-status=192.168.100.1 reachable ether1 distance=1 scope=30 target-scope=10
 4  Do  dst-address=192.168.0.0/24 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=30
 5 ADo  dst-address=192.168.1.0/24 gateway=192.168.100.202 gateway-status=192.168.100.202 reachable Stadium distance=110 scope=20 target-scope=10 ospf-metric=30 ospf-type=intra-area
 6 ADo  dst-address=192.168.2.0/24 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70 ospf-type=intra-area
 7 ADo  dst-address=192.168.12.0/24 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=90 ospf-type=intra-are>
 8 ADo  dst-address=192.168.15.0/24 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=20 ospf-type=intra-are>
 9 ADo  dst-address=192.168.16.0/24 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=20
10 ADo  dst-address=192.168.17.0/24 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=30
11 ADo  dst-address=192.168.19.0/24 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70 ospf-type=intra-are>
12 ADo  dst-address=192.168.21.0/24 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60 ospf-type=intra-are>
13 ADo  dst-address=192.168.23.0/24 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70 ospf-type=intra-are>
14 ADo  dst-address=192.168.42.0/24 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40 ospf-type=intra-are>
15 ADo  dst-address=192.168.87.0/24 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
        ospf-type=external-type-2
16 ADC  dst-address=192.168.100.0/30 pref-src=192.168.100.2 gateway=ether1 gateway-status=ether1 reachable distance=0 scope=10
17 ADo  dst-address=192.168.100.4/30 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
18 ADo  dst-address=192.168.100.8/29 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60
19 ADo  dst-address=192.168.100.16/28 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=20
20 ADo  dst-address=192.168.100.40/30 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=30
21 ADo  dst-address=192.168.100.44/30 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
22 ADo  dst-address=192.168.100.60/30 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60
23 ADo  dst-address=192.168.100.100/30 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
24 ADo  dst-address=192.168.100.101/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
25 ADo  dst-address=192.168.100.104/30 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=50
26 ADo  dst-address=192.168.100.108/30 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=50
27 ADo  dst-address=192.168.100.120/30 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60
28 ADC  dst-address=192.168.100.124/30 pref-src=192.168.100.126 gateway=Hunters gateway-status=Hunters reachable distance=0 scope=10
29 ADC  dst-address=192.168.100.152/30 pref-src=192.168.100.153 gateway=Belvidere gateway-status=Belvidere reachable distance=0 scope=10
30 ADo  dst-address=192.168.100.156/30 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
31 ADo  dst-address=192.168.100.161/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=20
32 ADo  dst-address=192.168.100.162/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=20
33 ADo  dst-address=192.168.100.188/30 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=80
34 ADC  dst-address=192.168.100.200/30 pref-src=192.168.100.201 gateway=Stadium gateway-status=Stadium reachable distance=0 scope=10
35 ADo  dst-address=192.168.100.204/30 gateway=192.168.100.202 gateway-status=192.168.100.202 reachable Stadium distance=110 scope=20 target-scope=10 ospf-metric=20
36 ADo  dst-address=192.168.101.16/30 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60
37 ADo  dst-address=192.168.102.8/29 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=20
38 ADo  dst-address=192.168.102.16/29 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=20
39 ADC  dst-address=192.168.104.172/32 pref-src=192.168.104.176 gateway=<pppoe-katt> gateway-status=<pppoe-katt> reachable distance=0 scope=10
40 ADC  dst-address=192.168.104.220/32 pref-src=192.168.104.223 gateway=<pppoe-janie> gateway-status=<pppoe-janie> reachable distance=0 scope=10
41 ADo  dst-address=192.168.121.26/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=90
42 ADo  dst-address=192.168.121.44/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
43 ADo  dst-address=192.168.121.91/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
44 ADo  dst-address=192.168.121.245/32 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=30
45 ADo  dst-address=192.168.121.249/32 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=30
46 ADo  dst-address=192.168.121.253/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=20
47 ADC  dst-address=192.168.140.2/32 pref-src=192.168.140.1 gateway=<pppoe-radius-1> gateway-status=<pppoe-radius-1> reachable distance=0 scope=10
48 ADo  dst-address=192.168.140.18/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=90
49 ADo  dst-address=192.168.140.28/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60
50 ADo  dst-address=192.168.140.30/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
51 ADo  dst-address=192.168.140.34/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
52 ADo  dst-address=192.168.141.2/32 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=30
53 ADo  dst-address=192.168.151.226/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=20
54 ADo  dst-address=192.168.151.232/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=20
55 ADo  dst-address=192.168.151.237/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=20
56 ADo  dst-address=192.168.151.242/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=20
57 ADo  dst-address=192.168.151.244/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=20
58 ADo  dst-address=192.168.151.248/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=20
59 ADo  dst-address=192.168.152.34/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
60 ADo  dst-address=192.168.152.57/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
61 ADo  dst-address=192.168.152.74/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
62 ADo  dst-address=192.168.152.75/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
63 ADo  dst-address=192.168.152.79/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
64 ADo  dst-address=192.168.152.86/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
65 ADo  dst-address=192.168.152.88/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
66 ADo  dst-address=192.168.152.90/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
67 ADo  dst-address=192.168.152.91/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
68 ADo  dst-address=192.168.152.92/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
69 ADo  dst-address=192.168.152.96/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
70 ADo  dst-address=192.168.152.102/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
71 ADo  dst-address=192.168.152.109/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
72 ADo  dst-address=192.168.152.125/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
73 ADo  dst-address=192.168.152.139/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
74 ADo  dst-address=192.168.152.141/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
75 ADo  dst-address=192.168.152.154/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
76 ADo  dst-address=192.168.152.170/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
77 ADo  dst-address=192.168.152.172/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
78 ADo  dst-address=192.168.152.200/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
79 ADo  dst-address=192.168.152.201/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
80 ADo  dst-address=192.168.152.206/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
81 ADo  dst-address=192.168.152.209/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
82 ADo  dst-address=192.168.152.211/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
83 ADo  dst-address=192.168.152.218/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
84 ADo  dst-address=192.168.152.237/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
85 ADo  dst-address=192.168.152.240/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
86 ADo  dst-address=192.168.152.241/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
87 ADo  dst-address=192.168.152.243/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
88 ADo  dst-address=192.168.152.244/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
89 ADo  dst-address=192.168.152.245/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
90 ADo  dst-address=192.168.152.246/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=40
91 ADo  dst-address=192.168.153.33/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=50
92 ADo  dst-address=192.168.153.36/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=50
93 ADo  dst-address=192.168.153.111/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=50
94 ADo  dst-address=192.168.154.20/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60
95 ADo  dst-address=192.168.154.21/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60
96 ADo  dst-address=192.168.154.22/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60
97 ADo  dst-address=192.168.154.23/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60
98 ADo  dst-address=192.168.154.24/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60
99 ADo  dst-address=192.168.154.27/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60
100 ADo  dst-address=192.168.154.28/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60
101 ADo  dst-address=192.168.154.30/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60
102 ADo  dst-address=192.168.154.47/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60
103 ADo  dst-address=192.168.154.49/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60
104 ADo  dst-address=192.168.154.84/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60
105 ADo  dst-address=192.168.154.164/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60
106 ADo  dst-address=192.168.154.177/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60
107 ADo  dst-address=192.168.154.210/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60
108 ADo  dst-address=192.168.154.219/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60
109 ADo  dst-address=192.168.154.221/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60
110 ADo  dst-address=192.168.154.243/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60
111 ADo  dst-address=192.168.154.252/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60
112 ADo  dst-address=192.168.155.37/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
113 ADo  dst-address=192.168.155.46/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
114 ADo  dst-address=192.168.155.140/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
115 ADo  dst-address=192.168.155.164/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
116 ADo  dst-address=192.168.155.181/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
117 ADo  dst-address=192.168.155.193/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
118 ADo  dst-address=192.168.155.194/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
119 ADo  dst-address=192.168.155.223/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
120 ADo  dst-address=192.168.156.34/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=80
121 ADo  dst-address=192.168.156.44/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=80
122 ADo  dst-address=192.168.156.171/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=80
123 ADo  dst-address=192.168.156.203/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=80
124 ADo  dst-address=192.168.156.242/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=80
125 ADo  dst-address=192.168.156.252/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=80
126 ADo  dst-address=192.168.156.254/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=80
127 ADo  dst-address=192.168.157.63/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=90
128 ADo  dst-address=192.168.157.65/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=90
129 ADo  dst-address=192.168.158.245/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
130 ADo  dst-address=192.168.159.212/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
131 ADo  dst-address=192.168.159.216/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
132 ADo  dst-address=192.168.159.217/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
133 ADo  dst-address=192.168.159.231/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
134 ADo  dst-address=192.168.159.233/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
135 ADo  dst-address=192.168.159.234/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
136 ADo  dst-address=192.168.159.236/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
137 ADo  dst-address=192.168.159.240/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
138 ADo  dst-address=192.168.160.96/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=30
139 ADo  dst-address=192.168.160.99/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=30
140 ADo  dst-address=192.168.163.241/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
141 ADo  dst-address=192.168.163.243/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
142 ADo  dst-address=192.168.164.29/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=80
143 ADo  dst-address=192.168.164.78/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=80
144 ADo  dst-address=192.168.164.129/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=80
145 ADo  dst-address=192.168.164.218/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=80
146 ADo  dst-address=192.168.164.219/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=80
147 ADo  dst-address=192.168.164.220/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=80
148 ADo  dst-address=192.168.165.163/32 gateway=192.168.100.202 gateway-status=192.168.100.202 reachable Stadium distance=110 scope=20 target-scope=10 ospf-metric=20
149 ADo  dst-address=192.168.165.171/32 gateway=192.168.100.202 gateway-status=192.168.100.202 reachable Stadium distance=110 scope=20 target-scope=10 ospf-metric=20
150 ADo  dst-address=192.168.165.177/32 gateway=192.168.100.202 gateway-status=192.168.100.202 reachable Stadium distance=110 scope=20 target-scope=10 ospf-metric=20
151 ADo  dst-address=192.168.166.246/32 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=30
152 ADo  dst-address=192.168.166.249/32 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=30
153 ADo  dst-address=192.168.166.253/32 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=30
154 ADo  dst-address=192.168.167.2/32 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=30
155 ADo  dst-address=192.168.167.3/32 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=30
156 ADo  dst-address=192.168.167.22/32 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=30
157 ADo  dst-address=192.168.167.33/32 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=30
158 ADo  dst-address=192.168.167.34/32 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=30
159 ADo  dst-address=192.168.167.81/32 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=30
160 ADo  dst-address=192.168.167.98/32 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=30
161 ADo  dst-address=192.168.167.102/32 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=30
162 ADo  dst-address=192.168.167.251/32 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=30
163 ADo  dst-address=192.168.167.252/32 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=30
164 ADo  dst-address=192.168.167.253/32 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=30
165 ADo  dst-address=192.168.168.227/32 gateway=192.168.100.202 gateway-status=192.168.100.202 reachable Stadium distance=110 scope=20 target-scope=10 ospf-metric=30
166 ADo  dst-address=192.168.168.249/32 gateway=192.168.100.202 gateway-status=192.168.100.202 reachable Stadium distance=110 scope=20 target-scope=10 ospf-metric=30
167 ADo  dst-address=192.168.168.251/32 gateway=192.168.100.202 gateway-status=192.168.100.202 reachable Stadium distance=110 scope=20 target-scope=10 ospf-metric=30
168 ADo  dst-address=192.168.168.253/32 gateway=192.168.100.202 gateway-status=192.168.100.202 reachable Stadium distance=110 scope=20 target-scope=10 ospf-metric=30
169 ADo  dst-address=192.168.169.16/32 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=30
170 ADo  dst-address=192.168.169.22/32 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=30
171 ADo  dst-address=192.168.169.37/32 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=30
172 ADo  dst-address=192.168.169.98/32 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=30
173 ADo  dst-address=192.168.169.99/32 gateway=192.168.100.154 gateway-status=192.168.100.154 reachable Belvidere distance=110 scope=20 target-scope=10 ospf-metric=30
174 ADo  dst-address=192.168.171.162/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=80
175 ADo  dst-address=192.168.173.0/24 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=30
176 ADo  dst-address=192.168.173.99/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=60
177 ADo  dst-address=192.168.209.246/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=80
178 ADo  dst-address=192.168.209.248/32 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=70
179 ADo  dst-address=192.168.250.0/24 gateway=192.168.100.125 gateway-status=192.168.100.125 reachable Hunters distance=110 scope=20 target-scope=10 ospf-metric=30
180 ADC  dst-address=192.168.252.0/24 pref-src=192.168.252.1 gateway=ether2 gateway-status=ether2 reachable distance=0 scope=10
181 ADC  dst-address=192.168.253.0/24 pref-src=192.168.253.1 gateway=ether3 gateway-status=ether3 reachable distance=0 scope=10
# jun/08/2011 09:34:29 by RouterOS 4.17
# software id = TMY7-IFE2
/routing ospf instance
set default comment="" disabled=no distribute-default=never in-filter=ospf-in metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=auto metric-rip=20 \
    metric-static=20 name=default out-filter=ospf-out redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=as-type-2 redistribute-rip=no redistribute-static=\
    as-type-2 router-id=192.168.100.126
/routing ospf area
set backbone area-id=0.0.0.0 comment="" disabled=no instance=default name=backbone type=default
/routing ospf area range
add advertise=yes area=backbone comment="" cost=calculated disabled=no range=0.0.0.0/0
/routing ospf interface
add authentication=none authentication-key="" authentication-key-id=1 comment="" cost=10 dead-interval=40s disabled=no hello-interval=10s instance-id=0 interface=ether3 \
    network-type=broadcast passive=yes priority=1 retransmit-interval=5s transmit-delay=1s use-bfd=no
/routing ospf network
add area=backbone comment="" disabled=no network=0.0.0.0/0
add area=backbone comment="" disabled=no network=192.168.253.0/24
 instance=default area=backbone type=router id=192.168.100.6 originator=192.168.100.6 sequence-number=0x80000685 age=358 checksum=0x5847 options="E" body=
     flags=
         link-type=Stub id=192.168.171.162 data=255.255.255.255 metric=10
         link-type=Transit id=192.168.100.5 data=192.168.100.6 metric=10
 instance=default area=backbone type=router id=192.168.100.10 originator=192.168.100.10 sequence-number=0x8000357F age=423 checksum=0x2A97 options="E" body=
     flags=EXTERNAL
         link-type=Stub id=192.168.19.0 data=255.255.255.0 metric=10
         link-type=Transit id=192.168.100.5 data=192.168.100.5 metric=10
         link-type=Transit id=192.168.100.46 data=192.168.100.45 metric=10
         link-type=Stub id=192.168.155.193 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.121.44 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.155.37 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.155.194 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.155.223 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.155.46 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.155.140 data=255.255.255.255 metric=10
         link-type=Transit id=192.168.100.9 data=192.168.100.10 metric=10
         link-type=Stub id=192.168.155.181 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.209.248 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.155.164 data=255.255.255.255 metric=10
 instance=default area=backbone type=router id=192.168.100.17 originator=192.168.100.17 sequence-number=0x800005E4 age=435 checksum=0xCE81 options="E" body=
     flags=EXTERNAL
         link-type=Transit id=192.168.100.18 data=192.168.100.17 metric=10
         link-type=Stub id=192.168.250.0 data=255.255.255.0 metric=10
         link-type=Transit id=192.168.100.42 data=192.168.100.41 metric=10
         link-type=Stub id=192.168.160.99 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.160.96 data=255.255.255.255 metric=10
 instance=default area=backbone type=router id=192.168.100.46 originator=192.168.100.46 sequence-number=0x8000BC15 age=648 checksum=0xA1D4 options="E" body=
     flags=
         link-type=Stub id=192.168.156.44 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.209.246 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.156.254 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.156.34 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.156.203 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.156.252 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.156.242 data=255.255.255.255 metric=10
         link-type=Transit id=192.168.100.46 data=192.168.100.46 metric=10
         link-type=Stub id=192.168.156.171 data=255.255.255.255 metric=10
         link-type=Transit id=192.168.100.190 data=192.168.100.189 metric=10
 instance=default area=backbone type=router id=192.168.100.62 originator=192.168.100.62 sequence-number=0x8000001D age=460 checksum=0xECF9 options="E" body=
     flags=
         link-type=Transit id=192.168.100.61 data=192.168.100.62 metric=10
         link-type=Stub id=192.168.158.245 data=255.255.255.255 metric=10
 instance=default area=backbone type=router id=192.168.100.101 originator=192.168.100.101 sequence-number=0x8000092E age=1296 checksum=0xEC34 options="E" body=
     flags=
         link-type=Stub id=192.168.153.33 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.153.36 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.153.111 data=255.255.255.255 metric=10
         link-type=Transit id=192.168.100.106 data=192.168.100.105 metric=10
         link-type=Transit id=192.168.100.110 data=192.168.100.109 metric=10
         link-type=Transit id=192.168.100.102 data=192.168.100.101 metric=10
 instance=default area=backbone type=router id=192.168.100.102 originator=192.168.100.102 sequence-number=0x800033A0 age=439 checksum=0xB2EA options="E" body=
     flags=EXTERNAL
         link-type=Transit id=192.168.100.42 data=192.168.100.42 metric=10
         link-type=Stub id=192.168.42.0 data=255.255.255.0 metric=10
         link-type=Stub id=192.168.152.88 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.140.30 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.139 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.245 data=255.255.255.255 metric=10
         link-type=Transit id=192.168.100.102 data=192.168.100.102 metric=10
         link-type=Stub id=192.168.152.91 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.79 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.109 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.206 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.172 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.102 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.96 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.246 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.237 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.218 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.244 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.34 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.90 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.209 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.75 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.241 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.121.91 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.200 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.92 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.74 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.141 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.154 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.125 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.211 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.240 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.170 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.57 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.201 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.86 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.152.243 data=255.255.255.255 metric=10
 instance=default area=backbone type=router id=192.168.100.106 originator=192.168.100.106 sequence-number=0x80004CC6 age=236 checksum=0x3FF0 options="E" body=
     flags=EXTERNAL
         link-type=Transit id=192.168.100.106 data=192.168.100.106 metric=10
         link-type=Transit id=192.168.100.9 data=192.168.100.9 metric=10
         link-type=Stub id=192.168.154.49 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.140.28 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.154.243 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.154.20 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.154.210 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.154.47 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.154.164 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.154.24 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.21.0 data=255.255.255.0 metric=10
         link-type=Stub id=192.168.154.219 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.154.252 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.154.84 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.154.21 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.154.177 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.154.27 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.154.30 data=255.255.255.255 metric=10
         link-type=Transit id=192.168.100.61 data=192.168.100.61 metric=10
         link-type=Stub id=192.168.154.23 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.154.22 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.154.28 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.154.221 data=255.255.255.255 metric=10
 instance=default area=backbone type=router id=192.168.100.110 originator=192.168.100.110 sequence-number=0x80000505 age=212 checksum=0x4B82 options="E" body=
     flags=
         link-type=Transit id=192.168.100.110 data=192.168.100.110 metric=10
         link-type=Transit id=192.168.101.18 data=192.168.101.17 metric=10
         link-type=Transit id=192.168.100.122 data=192.168.100.121 metric=10
 instance=default area=backbone type=router id=192.168.100.122 originator=192.168.100.122 sequence-number=0x80000597 age=1181 checksum=0x57FC options="E" body=
     flags=
         link-type=Transit id=192.168.100.158 data=192.168.100.157 metric=10
         link-type=Stub id=192.168.2.0 data=255.255.255.0 metric=10
         link-type=Stub id=192.168.163.241 data=255.255.255.255 metric=10
         link-type=Transit id=192.168.100.122 data=192.168.100.122 metric=10
         link-type=Stub id=10.5.51.0 data=255.255.255.0 metric=10
         link-type=Stub id=192.168.163.243 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.140.34 data=255.255.255.255 metric=10
 instance=default area=backbone type=router id=192.168.100.125 originator=192.168.100.125 sequence-number=0x80000625 age=67 checksum=0x123B options="E" body=
     flags=EXTERNAL
         link-type=Transit id=192.168.100.126 data=192.168.100.125 metric=10
         link-type=Stub id=192.168.151.225 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.151.248 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.151.232 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.151.244 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.151.242 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.151.237 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.121.253 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.15.0 data=255.255.255.0 metric=10
         link-type=Transit id=192.168.100.18 data=192.168.100.18 metric=10
 instance=default area=backbone type=router id=192.168.100.126 originator=192.168.100.126 sequence-number=0x800005A5 age=1728 checksum=0x518F options="E" body=
     flags=EXTERNAL
         link-type=Stub id=192.168.104.172 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.253.0 data=255.255.255.0 metric=10
         link-type=Stub id=192.168.140.2 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.100.0 data=255.255.255.252 metric=10
         link-type=Stub id=192.168.252.0 data=255.255.255.0 metric=10
         link-type=Transit id=192.168.100.126 data=192.168.100.126 metric=10
         link-type=Stub id=192.168.104.220 data=255.255.255.255 metric=10
         link-type=Transit id=192.168.100.202 data=192.168.100.201 metric=10
         link-type=Transit id=192.168.100.154 data=192.168.100.153 metric=10
 instance=default area=backbone type=router id=192.168.100.154 originator=192.168.100.154 sequence-number=0x800005A0 age=175 checksum=0xC8FD options="E" body=
     flags=
         link-type=Transit id=192.168.102.19 data=192.168.102.17 metric=10
         link-type=Transit id=192.168.102.11 data=192.168.102.9 metric=10
         link-type=Transit id=192.168.100.154 data=192.168.100.154 metric=10
         link-type=Stub id=192.168.16.0 data=255.255.255.0 metric=10
 instance=default area=backbone type=router id=192.168.100.158 originator=192.168.100.158 sequence-number=0x800007D5 age=1112 checksum=0x6DDD options="E" body=
     flags=
         link-type=Stub id=192.168.164.219 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.164.218 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.164.220 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.164.78 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.164.29 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.164.129 data=255.255.255.255 metric=10
         link-type=Transit id=192.168.100.158 data=192.168.100.158 metric=10
 instance=default area=backbone type=router id=192.168.100.190 originator=192.168.100.190 sequence-number=0x800016F5 age=870 checksum=0xF38D options="E" body=
     flags=
         link-type=Stub id=192.168.157.65 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.12.0 data=255.255.255.0 metric=10
         link-type=Stub id=192.168.157.63 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.121.26 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.140.18 data=255.255.255.255 metric=10
         link-type=Transit id=192.168.100.190 data=192.168.100.190 metric=10
 instance=default area=backbone type=router id=192.168.100.202 originator=192.168.100.202 sequence-number=0x80000CBC age=951 checksum=0x3ABC options="E" body=
     flags=
         link-type=Stub id=192.168.165.163 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.165.171 data=255.255.255.255 metric=10
         link-type=Transit id=192.168.100.206 data=192.168.100.205 metric=10
         link-type=Stub id=192.168.165.177 data=255.255.255.255 metric=10
         link-type=Transit id=192.168.100.202 data=192.168.100.202 metric=10
         link-type=Stub id=10.5.50.0 data=255.255.255.0 metric=10
 instance=default area=backbone type=router id=192.168.100.206 originator=192.168.100.206 sequence-number=0x80001535 age=194 checksum=0x661B options="E" body=
     flags=
         link-type=Stub id=192.168.168.227 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.168.249 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.168.253 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.168.251 data=255.255.255.255 metric=10
         link-type=Transit id=192.168.100.206 data=192.168.100.206 metric=10
         link-type=Stub id=192.168.1.0 data=255.255.255.0 metric=10
 instance=default area=backbone type=router id=192.168.101.18 originator=192.168.101.18 sequence-number=0x8000072E age=254 checksum=0x16A6 options="E" body=
     flags=
         link-type=Stub id=192.168.23.0 data=255.255.255.0 metric=10
         link-type=Stub id=192.168.159.212 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.159.234 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.159.240 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.159.231 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.159.236 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.159.217 data=255.255.255.255 metric=10
         link-type=Transit id=192.168.101.18 data=192.168.101.18 metric=10
         link-type=Stub id=192.168.159.216 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.159.233 data=255.255.255.255 metric=10
 instance=default area=backbone type=router id=192.168.102.10 originator=192.168.102.10 sequence-number=0x80000724 age=1113 checksum=0x3BB3 options="E" body=
     flags=
         link-type=Transit id=192.168.102.11 data=192.168.102.10 metric=10
         link-type=Stub id=192.168.17.0 data=255.255.255.0 metric=10
         link-type=Stub id=192.168.167.3 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.167.33 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.167.251 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.121.245 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.167.253 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.121.249 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.167.81 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.167.252 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.167.22 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.167.98 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.167.2 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.167.34 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.167.102 data=255.255.255.255 metric=10
 instance=default area=backbone type=router id=192.168.102.11 originator=192.168.102.11 sequence-number=0x8000063D age=1636 checksum=0x9194 options="E" body=
     flags=
         link-type=Transit id=192.168.102.11 data=192.168.102.11 metric=10
         link-type=Stub id=192.168.169.16 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.169.98 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.169.99 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.169.37 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.169.22 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.0.0 data=255.255.255.0 metric=10
 instance=default area=backbone type=router id=192.168.102.18 originator=192.168.102.18 sequence-number=0x8000000B age=1343 checksum=0xDC6D options="E" body=
     flags=
         link-type=Stub id=192.168.166.253 data=255.255.255.255 metric=10
         link-type=Transit id=192.168.102.19 data=192.168.102.18 metric=10
         link-type=Stub id=192.168.166.249 data=255.255.255.255 metric=10
         link-type=Stub id=192.168.166.246 data=255.255.255.255 metric=10
 instance=default area=backbone type=router id=192.168.102.19 originator=192.168.102.19 sequence-number=0x80000177 age=1228 checksum=0x1E16 options="E" body=
     flags=
         link-type=Stub id=192.168.141.2 data=255.255.255.255 metric=10
         link-type=Transit id=192.168.102.19 data=192.168.102.19 metric=10
 instance=default area=backbone type=network id=192.168.100.5 originator=192.168.100.10 sequence-number=0x8000064A age=197 checksum=0xA314 options="E" body=
     netmask=255.255.255.252
         routerId=192.168.100.10
         routerId=192.168.100.6
 instance=default area=backbone type=network id=192.168.100.9 originator=192.168.100.106 sequence-number=0x80001011 age=551 checksum=0x71B0 options="E" body=
     netmask=255.255.255.248
         routerId=192.168.100.106
 instance=default area=backbone type=network id=192.168.100.18 originator=192.168.100.125 sequence-number=0x80000509 age=72 checksum=0xC640 options="E" body=
     netmask=255.255.255.240
         routerId=192.168.100.125
         routerId=192.168.100.17
 instance=default area=backbone type=network id=192.168.100.42 originator=192.168.100.102 sequence-number=0x80000507 age=86 checksum=0xC54D options="E" body=
         routerId=192.168.100.102
 instance=default area=backbone type=network id=192.168.100.46 originator=192.168.100.46 sequence-number=0x8000274E age=126 checksum=0x65B7 options="E" body=
         routerId=192.168.100.46
 instance=default area=backbone type=network id=192.168.100.61 originator=192.168.100.106 sequence-number=0x8000001B age=462 checksum=0x7645 options="E" body=
         routerId=192.168.100.62
 instance=default area=backbone type=network id=192.168.100.102 originator=192.168.100.102 sequence-number=0x80000500 age=558 checksum=0x1673 options="E"
   body=
         routerId=192.168.100.101
 instance=default area=backbone type=network id=192.168.100.106 originator=192.168.100.106 sequence-number=0x80000505 age=1476 checksum=0xF384 options="E"
   body=
 instance=default area=backbone type=network id=192.168.100.110 originator=192.168.100.110 sequence-number=0x80000500 age=247 checksum=0xE58B options="E"
   body=
         routerId=192.168.100.110
 instance=default area=backbone type=network id=192.168.100.122 originator=192.168.100.122 sequence-number=0x80000500 age=283 checksum=0x1C28 options="E"
   body=
         routerId=192.168.100.122
 instance=default area=backbone type=network id=192.168.100.126 originator=192.168.100.126 sequence-number=0x80000504 age=442 checksum=0xCE56 options="E"
   body=
         routerId=192.168.100.126
 instance=default area=backbone type=network id=192.168.100.154 originator=192.168.100.154 sequence-number=0x80000502 age=188 checksum=0x3899 options="E"
   body=
         routerId=192.168.100.154
 instance=default area=external type=as-external id=192.168.87.0 originator=192.168.100.10 sequence-number=0x80000083 age=1397 checksum=0xA2CC options="E" body=
     netmask=255.255.255.0
     forwarding-address=192.168.209.248
     metric=20
     route-tag=0x0
     type2
 instance=default area=external type=as-external id=192.168.100.101 originator=192.168.100.102 sequence-number=0x80000501 age=604 checksum=0x56C7 options="E"
   body=
     netmask=255.255.255.255
     forwarding-address=192.168.100.102
     metric=20
     route-tag=0x0
     type2
 instance=default area=external type=as-external id=192.168.100.161 originator=192.168.100.125 sequence-number=0x8000050B age=113 checksum=0x709 options="E"
   body=
     forwarding-address=192.168.100.23
     metric=20
     route-tag=0x0
     type2
 instance=default area=external type=as-external id=192.168.100.162 originator=192.168.100.125 sequence-number=0x8000050B age=113 checksum=0xFC12 options="E"
   body=
     metric=20
     route-tag=0x0
     type2
 instance=default area=external type=as-external id=192.168.173.0 originator=192.168.100.17 sequence-number=0x80000507 age=115 checksum=0xCEF6 options="E" body=
     forwarding-address=192.168.100.42
     metric=20
     route-tag=0x0
     type2
 instance=default area=external type=as-external id=192.168.173.0 originator=192.168.100.106 sequence-number=0x8000001C age=511 checksum=0xB493 options="E"
   body=
     forwarding-address=192.168.100.62
     metric=20
     route-tag=0x0
     type2
 instance=default area=external type=as-external id=192.168.173.99 originator=192.168.100.106 sequence-number=0x8000001C age=511 checksum=0xD212 options="E"
   body=
     metric=20
     route-tag=0x0
     type2
According to that everything should be peachy. Below is the router LSA for the router with the new network connected to it.
     flags=EXTERNAL
It includes that link in its announcement. All other routers should be knowing about that link, and have a route to it.
Try this on a different router in the same area, and post the results. Also, it does make it much easier to read if you include the command that generated that output. Instead of posting just the output of “/ip route print”, also copy the part where you run the command so that it’s included in the snippet you post.
/routing ospf lsa print detail where id=192.168.100.126
/ip route print where 192.168.253.0 in dst-address
Does that router LSA show the link for id=192.168.253.0 and data=255.255.255.0? Does the route search bring up anything? All your routers are in the same area, so they should all have the same LSDB. The one you posted here doesn’t contain any conflicting LSAs for that subnet.
sorry about that, i wasn’t really sure what it was you were looking for
I’ve taken these out of one router over
     flags=EXTERNAL
         link-type=Stub id=192.168.104.165 data=255.255.255.255 metric=10
         [color=#800000]link-type=Stub id=192.168.253.0 data=255.255.255.0 metric=10[/color]
so it looks like the LSA for 192.168.253.0/24 is there
180 ADo  192.168.253.0/24                   192.168.100.201    110
and there we have the route
But all i can ping i ether3 on the first router which has 192.168.253.1 as its IP and not the server behind it which has 192.168.253.8 as its ip
the moment i get a chance i need to fire up my virtual network and play around there, test some of the stuff you told me and see if it works there
If you can ping the router’s IP on the network then everyone can reach that network. The other routers don’t care whether an IP on that network is implemented on a router or a server. The route is for an entire network - every node on the network is treated the same as far as the routing table goes.
The three most likely causes at this point aren’t OSPF related at all. OSPF and routing look absolutely fine. In order of likelihood:
  1. The server doesn’t have the right default gateway, so it doesn’t know how to get traffic back to destinations that aren’t on the same subnet as itself.
  2. The host firewall on the server is misconfigured.
  3. The router firewall on the router the network connects to is misconfigured.
hmmm
great, back to square one
The server is running ubuntu and from what i could see the firewall wasn’t even running. as for the default gateway it have it pointed at that networks wan port, 192.168.253.1
i think i need to find someone who can have a look at the system because the more i’m looking at it the more it thinking that i’ll never find the problem :frowning:
Edit: just gonna add that the server can ping out onto the network no problem although if i try to putty it won’t work.
I’m going to take a look round the server for a firewall but from what i’ve read on the net about ubuntu firewall it seems to be inactive :confused:
