Hello ,
I’m tryin to remove dhcp clients by using this all this commands (every time another command…) :
mikrotik.Send("/ip/dhcp-server/lease/remove");
mikrotik.Send("?=server=dhcp1" , true);
mikrotik.Send("?server=dhcp1" , true);
mikrotik.Send("?server=all" , true);
mikrotik.Send("?=server=all" , true);
foreach ?(string m in mikrotik.Read())
in all of them I get no error - “!done”
but it doesn’t remove nothing …
but when I do this :
mikrotik.Send("=.id=*2" , true);
it remove me the *2 client…
why?
what is wrong?
Thanks ,
You are using a query word in a non-print operation, which is not supported.
https://wiki.mikrotik.com/wiki/Manual:API#Queries
print command > accepts query words that limit set of returned sentences. This feature is available since RouterOS 3.21.
Alternative is to query first and then remove by id:
var ids = new List<string>();
mikrotik.Send("/ip/dhcp-server/lease/print");
mikrotik.Send("?-server", true);
foreach (var h in mikrotik.Read())
var startIndex = h.IndexOf(".id=") + 4;
if (startIndex >= 4)
var endIndex = h.IndexOf("=", startIndex);
var id = h.Substring(startIndex, endIndex - startIndex);
ids.Add(id);
foreach (var id in ids)
mikrotik.Send("=.id=" + id, true);
Console.WriteLine(mikrotik.Read());
Note that while Winbox shows server=all, the server is actually undefined for these entries (query word -server).
yes ,
this is what I did for now
saved all the Id and then remove them 1 by 1
Thanks ,
The Tik4Net (strong-typed entity) example:
https://github.com/danikf/tik4net
using tik4net;
using tik4net.Objects;
using tik4net.Objects.Ip.DhcpServer;
var host = "192.168.88.1";
var user = "admin";
var pass = "password";
using (var conn = tik4net.ConnectionFactory.OpenConnection(TikConnectionType.Api, host, user, pass))
var filter = conn.CreateParameter("-server", "");
var leases = conn.LoadList<DhcpServerLease>(filter);
foreach (var lease in leases)
conn.Delete(lease);
all my code is in the mikrotik API and not the Tik4Net
I wnat to start working with this - when I have time
Thanks ,
You have wasted a lot of time already. Just pointing out there are better and quicker solutions.
Assuming you have never installed a NuGet package?
