I've been digging through the forums trying to find an answer, but haven't had any luck so far...
I have a 5 port hEX that I'm trying to configure on my network. I am trying to configure the "LAN" ports (2,3,4,5) to have their own VLAN (ultimately there will be a 24 port switch, using VLAN tagging, sending different port groups to each interface of the router). When I first set up the router I was able to use port 2 (without VLAN configuration) to plug a laptop into, get a DHCP address, then browse the Internet. I then decided to configure ports 3,4,5 with vlans, dhcp servers, IP pools, etc. After what I thought was the correct configuration I connected a laptop to port 3 of the hEX. Unfortunately I cannot get the DHCP server to give a lease out to the laptop.
Any help would be greatly appreciated!!
Steve
Here is the configuration of my router:
oct/07/2017 21:11:32 by RouterOS 6.40.3
software id = 32WG-XHWQ
model = RouterBOARD 750G r3
serial number = 6F3906CA645C
set [ find default-name=ether2 ] name=ether2-master
/ip neighbor discovery
set ether1 discover=no
/interface vlan
add interface=ether2-master name=vlan10 vlan-id=10
add interface=ether4 name=vlan20 vlan-id=20
add interface=ether3 name=vlan30 vlan-id=30
add interface=ether4 name=vlan40 vlan-id=40
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp_poolUS ranges=192.168.88.6-192.168.88.254
add name=dhcp_pool40 ranges=192.168.40.6-192.168.40.254
add name=dhcp_pool20 ranges=192.168.20.6-192.168.20.254
add name=dhcp_pool30 ranges=192.168.30.6-192.168.30.254
add address-pool=dhcp_poolUS disabled=no interface=ether2-master lease-time=1d name=US
add address-pool=dhcp_pool40 disabled=no interface=vlan40 lease-time=1d name=dhcp40
add address-pool=dhcp_pool30 disabled=no interface=vlan30 lease-time=1d name=dhcp30
add address-pool=dhcp_pool20 disabled=no interface=vlan20 lease-time=1d name=dhcp20
add comment=defconf interface=ether2-master list=LAN
add address=192.168.88.1/24 comment=defconf interface=ether2-master network=192.168.88.0
add address=192.168.1.2/24 interface=ether1 network=192.168.1.0
add address=192.168.40.1/24 comment="IoT VLAN" interface=vlan40 network=192.168.40.0
add address=192.168.30.1/24 comment="Server VLAN" interface=vlan30 network=192.168.30.0
add address=192.168.20.1/24 comment="Guest VLAN" interface=vlan20 network=192.168.20.0
/ip dhcp-client
add dhcp-options=hostname,clientid interface=ether1
add address=192.168.20.0/24 comment="Guests and Screenwise Router" dns-server=192.168.1.1 gateway=192.168.20.1 netmask=24
add address=192.168.30.0/24 comment=Servers dns-server=192.168.1.1 gateway=192.168.30.1 netmask=24
add address=192.168.40.0/24 comment=IoT dns-server=192.168.1.1 gateway=192.168.40.1
add address=192.168.88.0/24 comment=Family dns-server=192.168.1.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=established,related,untracked disabled=yes
add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes protocol=icmp
add action=drop chain=input comment="defconf: drop all not coming from LAN" disabled=yes in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy" disabled=yes ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy" disabled=yes ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related disabled=yes
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=established,related,untracked disabled=yes
add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new disabled=yes in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes ipsec-policy=out,none out-interface-list=WAN
add distance=1 gateway=192.168.1.1
/snmp
set enabled=yes
/system clock
set time-zone-name=America/New_York
/system ntp client
set enabled=yes primary-ntp=18.26.4.105 secondary-ntp=129.6.15.29
/system routerboard mode-button
set enabled=no on-event=""
/tool mac-server
/tool mac-server mac-winbox
