Hi there
I have bought myself a mediaplayer that can connect to upnp and watch youtube etc.
The server that runs the upnp software is at the office.
Now i will need to configure 3 of the mikrotik routers to allow upnp.
Here is the layout of the network.
Server(172.16.1.1)----------Mikrotik1(rb750) eth1=172.16.1.200 ,eth2=172.16.0.201----------Mikrotik2(RB433) eth1=172.16.0.1 ,wlan1=172.23.128.1----------Mikrotik3(rb433) wlan1=172.23.128.2 ,eth1=192.168.4.1---------media player(192.168.4.3)
Should i setup it like this?
Mikrotik1
]/ip upnp> print
enabled: yes
allow-disable-external-interface: yes
show-dummy-rule: yes
/ip upnp interfaces> add interface=ether1 type=external
/ip upnp interfaces> add interface=ether2 type=internal
/ip upnp>
Mikrotik2
]/ip upnp> print
enabled: yes
/ip upnp interfaces> add interface=wlan1 type=internal
/ip upnp>
Mikrotik3
]/ip upnp> print
enabled: yes
/ip upnp interfaces> add interface=wlan1 type=external
/ip upnp interfaces> add interface=ether1 type=internal
/ip upnp>
Is this correct?
PS:I have also set nat+masquerade on Router1(rb750)
