Trying to upgrade mAP2n RouterOS but not enough storage on device
I just got two RBmAP2n’s and they have RouterOS 6.15. I want to upgrade them to the latest (6.27 - assuming it’s the mipsbe package I want) which is 10MB, problem is I only got about 4MB available flash storage on the device. What do I do? Thank you.
Do you have any other files in the “Files” folder" Or other packages that you don’t use?
Sorry for not getting back to you sooner.
Under “Files” it just showed two folders that I didn’t put there. The one was called “Skins” and I forget the other.
I’ve already installed the unit at a customer’s so I’m not able to access the config at this moment. I was just surprised that it comes from factory with such low available storage - not enough to perform the drag 'n drop upgrade.
As far as packages, I’m new to MikroTik and wouldn’t know what packages to remove. I’m just using the device as a simple AP, no routing.
Thank you for the reply.
Did you ever get anywhere with this?
Edit: my solution was the download&upgrade button.
