TUN works TAP doesn't WHY ? Need to Access to LAN pcs
Hi.
I fight for couple of days and still cant reach LAN PCs. I have newest soft of MT 6,41 Connection OpenVPN worsk but only on this configuration of client windows file:
# OpenVPN Client conf
client
nobind
persist-key
persist-tun
tls-client
# tls-remote xxxxxxxxxxxxxxxxxxxxxxxxx
ca cert_export_myCa.crt
cert cert_export_client1.crt
key cert_export_client1.key
remote MY_WAN_IP 1194
dev tun
#dev tap
proto tcp-client
# proto udp
cipher AES-256-CBC
auth SHA1
verb 4
ping 10
ping-restart 45
# ns-cert-type server
# comp-lzo
auth-user-pass secret
# auth-nocache
pull
route-method exe
route-delay 2
redirect-gateway def1
route 10.197.0.0 255.255.255.0 10.197.0.1
On Windows - tracert print:
Tabela tras IPv4
Aktywne trasy:
Miejsce docelowe w sieci   Maska sieci      Brama          Interfejs Metryka
          0.0.0.0          0.0.0.0      192.168.1.1      192.168.1.7     20
          0.0.0.0        128.0.0.0       10.197.0.1      10.197.0.26    276
       10.197.0.0    255.255.255.0         On-link       10.197.0.26    276
       10.197.0.0    255.255.255.0       10.197.0.1      10.197.0.26    276
      10.197.0.26  255.255.255.255         On-link       10.197.0.26    276
     10.197.0.255  255.255.255.255         On-link       10.197.0.26    276
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    306
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    306
  127.255.255.255  255.255.255.255         On-link         127.0.0.1    306
        128.0.0.0        128.0.0.0       10.197.0.1      10.197.0.26    276
  185.170.202.195  255.255.255.255      192.168.1.1      192.168.1.7    276
      192.168.1.0    255.255.255.0         On-link       192.168.1.7    276
      192.168.1.7  255.255.255.255         On-link       192.168.1.7    276
    192.168.1.255  255.255.255.255         On-link       192.168.1.7    276
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    306
        224.0.0.0        240.0.0.0         On-link       192.168.1.7    276
        224.0.0.0        240.0.0.0         On-link       10.197.0.26    276
  255.255.255.255  255.255.255.255         On-link         127.0.0.1    306
  255.255.255.255  255.255.255.255         On-link       192.168.1.7    276
  255.255.255.255  255.255.255.255         On-link       10.197.0.26    276
And MT log file:
14:50:49 2018 us=313022 Incoming Data Channel: Cipher 'AES-256-CBC' initialized with 256 bit key
Fri Jan 26 14:50:49 2018 us=313022 Incoming Data Channel: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Jan 26 14:50:49 2018 us=313022 interactive service msg_channel=372
Fri Jan 26 14:50:49 2018 us=316022 ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=10 HWADDR=74:d4:35:35:8e:5a
Fri Jan 26 14:50:49 2018 us=325023 open_tun
Fri Jan 26 14:50:49 2018 us=326023 TAP-WIN32 device [Połączenie lokalne 2] opened: \\.\Global\{E3F413DA-D1DE-4B8F-BA3C-37C3D5031CD3}.tap
Fri Jan 26 14:50:49 2018 us=326023 TAP-Windows Driver Version 9.21
Fri Jan 26 14:50:49 2018 us=326023 TAP-Windows MTU=1500
Fri Jan 26 14:50:49 2018 us=329023 Set TAP-Windows TUN subnet mode network/local/netmask = 10.197.0.0/10.197.0.29/255.255.255.0 [SUCCEEDED]
Fri Jan 26 14:50:49 2018 us=329023 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.197.0.29/255.255.255.0 on interface {E3F413DA-D1DE-4B8F-BA3C-37C3D5031CD3} [DHCP-serv: 10.197.0.254, lease-time: 31536000]
Fri Jan 26 14:50:49 2018 us=329023 DHCP option string: 06040ac5 0001
Fri Jan 26 14:50:49 2018 us=331023 Successful ARP Flush on interface [32] {E3F413DA-D1DE-4B8F-BA3C-37C3D5031CD3}
Fri Jan 26 14:50:49 2018 us=359025 do_ifconfig, tt->did_ifconfig_ipv6_setup=0
Fri Jan 26 14:50:49 2018 us=359025 MANAGEMENT: >STATE:1516974649,ASSIGN_IP,,10.197.0.29,,,,
Fri Jan 26 14:50:51 2018 us=135126 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
Fri Jan 26 14:50:51 2018 us=135126 C:\Windows\system32\route.exe ADD 185.170.202.195 MASK 255.255.255.255 192.168.1.1
Fri Jan 26 14:50:51 2018 us=136126 Route addition via service succeeded
Fri Jan 26 14:50:51 2018 us=136126 C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.197.0.28
Fri Jan 26 14:50:51 2018 us=138126 Route addition via service succeeded
Fri Jan 26 14:50:51 2018 us=139127 C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.197.0.28
Fri Jan 26 14:50:51 2018 us=140127 Route addition via service succeeded
Fri Jan 26 14:50:51 2018 us=140127 MANAGEMENT: >STATE:1516974651,ADD_ROUTES,,,,,,
Fri Jan 26 14:50:51 2018 us=140127 C:\Windows\system32\route.exe ADD 10.197.0.0 MASK 255.255.255.0 10.197.0.1
Fri Jan 26 14:50:51 2018 us=142127 Route addition via service succeeded
Fri Jan 26 14:50:51 2018 us=142127 Initialization Sequence Completed
Fri Jan 26 14:50:51 2018 us=142127 MANAGEMENT: >STATE:1516974651,CONNECTED,SUCCESS,10.197.0.29,MY_WAN_IP,1194,192.168.1.7,62419
And ping tests:
c:\Users\Admin\Desktop\certs>ping 10.197.0.1
Badanie 10.197.0.1 z 32 bajtami danych:
Odpowiedź z 10.197.0.1: bajtów=32 czas=85ms TTL=64
Odpowiedź z 10.197.0.1: bajtów=32 czas=60ms TTL=64
Odpowiedź z 10.197.0.1: bajtów=32 czas=90ms TTL=64
Odpowiedź z 10.197.0.1: bajtów=32 czas=89ms TTL=64
Statystyka badania ping dla 10.197.0.1:
    Pakiety: Wysłane = 4, Odebrane = 4, Utracone = 0
             (0% LOSS),
Szacunkowy czas błądzenia pakietów w millisekundach:
    Minimum = 60 ms, Maksimum = 90 ms, Czas średni = 81 ms
c:\Users\Admin\Desktop\certs>ping 10.197.0.225
Badanie 10.197.0.225 z 32 bajtami danych:
Upłynął limit czasu żądania.
Statystyka badania ping dla 10.197.0.225:
    Pakiety: Wysłane = 4, Odebrane = 0, Utracone = 4
             (100% LOSS),
Can You help me to reach inside of LAN ??
