Tuning point2point 802.11N, nv2
Hi all.
In a 5GHz point-to-point, using good parabolic antennas, good cables, well builded radios (411AH+R52Hn) and placing correctly antennas, what are the parameters to try to tune?
I use this:
  1. find a free frequency
  2. set regulatory domain
  3. play with antenna gain to calibrate output power
  4. set data rate default with advanced rate selection
  5. set hw retries = 7
  6. set preamble mde = short
Leave the rest as default.
Are there other parameters (also not visibile from winbox) to try to tune to obtain a good link ?
Site location is very important and proximity to other Wireless antenna’s + what distance is the link is Freznel zone clearance between point A to point B OK,which polarity are you using H or V, use very short cables to the Antenna’s, and is the antenna’s dish or mesh grid, set the antenna gain in winbox to 0db
thanks.
there are other parameters to tune in wireless interface to optimize a link (other than those listed)?
I usually use bridge ↔ station-bridge and don’t allow for data rates that require QAM64. Also I only use long guard interval.
I noticed QAM64 and the short Guard-Interval to be too risky to use (packet drops might occur, latency isn’t stable!)
This means only the following data-rates should be enabled in custom-mode:
5Ghz-A:
6, 9 ,12, 18, 24, 36 Mbps
MCS 5-GHz-N:
0, 1, 2, 3, 4
8, 9, 10, 11, 12
I don’t need the full sync of 270/300 Mbps.
IMO 162 Mbps on 802.11n with 2x2 Mimo is enough. This allows for 100Mbps half-duplex!
Everything that needs more throughput should be realised with licensed PtP-Links, or optical fibers.
thanks.
but guard interval is only for 802.11bmode or it works also for N?
