tunnel issue
guys i have a weird issue
not being able to run any kind of tunnel on my mikrotik
surely i have activated the pptp and l2tp and even other kind of tunneling protocols beside that restarted the router not even any clue about why is not running
in parallel my other mikrotik has almost the same configuration and all other tunneling protocols are running
i create the tunnel > the running tunnel state is always grayed (not running) !
any idea ???
which ROS version at device ?
4.44.1 OS version
rb1100AHx2
As usually - the first step when something behaves in an unexpected way is to show your configuration. See my automatic signature below for a hint on anonymisation if necessary.
in fact nothing important to show just a normal tunnel that have to be up the firsts minutes that I finish configuring it EVEN BEFORE CONFIGURING AN IP ON ITS INTERFACE AND THE ROUTE
pptp, l2tp and other protocols are enabled also..
already on my second router (which the tunnel must be peered with) everything is running well
WHILE in the first router case even the tunnel is not running “its not up”, THE RUNNING STATUS (down the panel) IS GREYED cant find a way to make it run is there
anything that i have missed cz thats not the first time i configure an ip tunnel but whats happening here is weired…
