I have long been using RB very successfully for tunnels and advanced routing and have been delighted. I have always had one problem that I have never been able to solve satisfactorily. A current setup has just raised a situation when a solution to this would be useful.
The problem is simple. I have two (or more) connections to the Internet. One is default gateway and one is used with policy routing for selected traffic. Failover changes the default gateway. I would like to be able to force general Internet traffic in default gateway and tunnels on the non-default gateway. I would also like to be able to split tunnels between the two lines as the tunnel line is now close to capacity.
The question I have been unable to answer is simple. Is there any way to force a tunnel to use a specific gateway? The tunnel to use is not important - I can use PPTP, L2TP, EoIP or IPIP as they are used simply to connect sites. I had thought the local interface in IPIP would work by selecting a command in mangle to tag traffic from the local IP address to add a routing mark, add a route table in routing then add a routing rule to lookup traffic with the route mark in the alternative table thus changing the gateway. I was unable to get this to work.
Any ideas or suggestions on similar solutions? Any comments would be gratefully received! Thanks in advance for your time and attention.
