Thank you for your reply!
I’m using the default scan list.
Here’s my wireless settings (station):
Mode: station wds
Band: 5GHz-A
Frequency: 5280MHz
Channel Width: 20MHz
Scan List: default
Wireless Protocol: any
Frequency Mode: manual-txpower
Everything is working ok; only when i set Channel Width to 40MHz, both on the station and the AP, i can’t register to the AP from the station.
[admin@MikroTik] /interface wireless> print
0 R name="wlan2" mtu=1500 mac-address=00:15:6D:68:9D:4F arp=enabled
interface-type=Atheros AR5413 mode=station-wds ssid="MikroTik"
frequency=5280 band=5ghz-a channel-width=20mhz scan-list=default
wireless-protocol=any antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=my_security_profile
compression=no
[admin@MikroTik] /interface wireless info> print
0 interface-type=Atheros AR5413
chip-info="mac:0xa/0x5, phy:0x61, a5:0x63, a2:0x0, eeprom:0x5003"
pci-info="00:14.0" capabilities=tx-power-control,ack-timeout-control,virtual-
ap,alignment-mode,noise-floor-control,scanning,burst-support,
nstreme,sniffing,power-channel,wmm,nv2
default-periodic-calibration=enabled
supported-bands=5ghz-a,5ghz-40mhz,5ghz-10mhz,5ghz-5mhz
5ghz-channels=5180:0,5185:0,5190:0,5195:0,5200:0,5205:0,5210:0,5215:0,5220:0,
5225:0,5230:0,5235:0,5240:0,5245:0,5250:0,5255:0,5260:0,5265:0,
5270:0,5275:0,5280:0,5285:0,5290:0,5295:0,5300:0,5305:0,5310:0,
5315:0,5320:0,5500:0,5505:0,5510:0,5515:0,5520:0,5525:0,5530:0,
5535:0,5540:0,5545:0,5550:0,5555:0,5560:0,5565:0,5570:0,5575:0,
5580:0,5585:0,5590:0,5595:0,5600:0,5605:0,5610:0,5615:0,5620:0,
5625:0,5630:0,5635:0,5640:0,5645:0,5650:0,5655:0,5660:0,5665:0,
5670:0,5675:0,5680:0,5685:0,5690:0,5695:0,5700:0
5ghz-turbo-channels=5210:0,5215:0,5220:0,5225:0,5230:0,5235:0,5240:0,5245:0,
5250:0,5255:0,5260:0,5265:0,5270:0,5275:0,5280:0,5285:0,
5290:0,5530:0,5535:0,5540:0,5545:0,5550:0,5555:0,5560:0,
5565:0,5570:0,5575:0,5580:0,5585:0,5590:0,5595:0,5600:0,
5605:0,5610:0,5615:0,5620:0,5625:0,5630:0,5635:0,5640:0,
5645:0,5650:0
5ghz-10mhz-power-channels=5175:0,5180:0,5185:0,5190:0,5195:0,5200:0,5205:0,
5245:0,5250:0,5255:0,5260:0,5265:0,5270:0,5275:0,
5315:0,5320:0,5325:0,5495:0,5500:0,5505:0,5510:0,
5515:0,5520:0,5525:0,5530:0,5535:0,5540:0,5545:0,
5550:0,5555:0,5560:0,5565:0,5570:0,5575:0,5580:0,
5620:0,5625:0,5630:0,5635:0,5640:0,5645:0,5650:0,
5655:0,5660:0,5665:0,5670:0,5675:0,5680:0,5685:0,
5690:0,5695:0,5700:0,5705:0
5ghz-5mhz-power-channels=5175:0,5180:0,5185:0,5190:0,5195:0,5200:0,5205:0,
5290:0,5295:0,5300:0,5305:0,5310:0,5315:0,5320:0,5325:0,
5495:0,5500:0,5505:0,5510:0,5515:0,5520:0,5525:0,5530:0,
5575:0,5580:0,5585:0,5590:0,5595:0,5600:0,5605:0,5610:0,
5615:0,5620:0,5625:0,5630:0,5635:0,5640:0,5645:0,5650:0,
5655:0,5660:0,5665:0,5670:0,5675:0,5680:0,5685:0,5690:0,
