Can I set TurboG in any channel if I have Superchannel? Let’s say in 2502Mhz? It’s not working for me and i want to see what am I wrong.
use the scan-list for client if you use customer frequency.
used already…client can see the AP but it can’ connect on any other channel than 2437. Thats why I ask again…can I use Turbo in any channel if I have superchannel?
Does you client have superchannel license?
offcourse…both client and AP have 3.11 with extrachannels. Modes are Bridge (at base) an Station (at client). Both have Atheros 5213 and RouterOS shows channels from 2192 to 2539.
TurboG work on supperchannels only thing you need is to add frequency in scan list on client side of course set band to turbo mode. Try couple of frequency some work good but on other don’t connect or very bad signal depends or wireless card maybe antena.
It works now. My mistake was that i put a range 2100-2600 in the scan list but when I put only one channel it worked.
Thanks.
