Hello, new user. I did some searching, but I think my issue is so simple it’s not already here or my search-fu is weak.
I picked up a powerbox because I need the passive poe in/out capability. What I don’t need is any WAN, NAT, firewall between port 1 (the poe in) and port 2-5. Just treat port 1 like the other ports.
I have enough knowledge to break things but not enough to figure out RouterOS and all the complexities of the deep configuration. If I’m starting from a fresh reset it sets up port 1 as a WAN type with routing. How do I make it “dumb”??
