Turn off LEDs using the MODE button
Well, Hello everyone!
I’ve been looking the wiki for the nesseccery commands I need to activate the dark-mode (turn off LEDs using the MODE button) on a RBcAPGi-5acD2nD, that I had just reset to no defaults. I couldn’t find anything, so I had to reset again to defaults to get it.
So, just in case if anyone ever needs it again, I will put it here.
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=jimmyz policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
/system routerboard mode-button
set enabled=yes on-event="system script run dark-mode"
If it is correct, maybe someone of the admins can publish it under Device Information
Thank you :slight_smile:!
Hello Friend!
That was exactly what I was needing, but in my RB it didn’t work (760iGS)
It only deactivates the blue power led, the activity LEDs on the ether ports remain on, as well as the PoE Out.
Do you have any idea what I can modify?
I read in wiki.mikrotik.com/wiki/Manual:System/LEDS:
RouterBoard LED description
RB760iGS (hEX S) Turns off Power LED and SFP LED
So I think it is hardware restriction.
The new help page is maybe wrong.
The wiki page is correct and Becs corrected it from all to only the Power LED and SFP leds.
https://wiki.mikrotik.com/index.php?title=Manual:System/LEDS&curid=5494&diff=33933&oldid=33661
it really is not important, but the wiki page was correct, what did becks corrected?
Help page is still wrong.
By helppage you mean the Manual inside Winbox. That is displaying the Wiki and states:
On the RB760iGS you can only control the Power and SFP LED.
Thank you, have a nice time!
I just noticed the the new docs is not updated on this.
https://help.mikrotik.com/docs/display/ROS/Device+Information#DeviceInformation-Health
