Could you, please, add a command to turn on the LCD backlight from the script. I would like to be able to turn it on using Traffic Monitor or Scheduler.
what do you mean by LCD backlight? For what purpose?
When option ‘backlight-timer’ is set to some time, LCD backlight turns off after preset time, and then I must touch it to turn backlight on. It is not convenient. Also, I will not use option ‘backlight-timer=never’ because I don’t want it to illuminate all night.
If there was a command ‘backlight=yes’ I could use it in script to turn on LCD at preset time of day (using Scheduler) or when traffic on gateway interface is detected (using Traffic Monitor)
I tried to execute ‘enabled=yes’ but LCD starts with menu instead of previously selected graph. I just want it to show graph that was selected before it timed out.
Mikrotik RB2011UAS-2HnD-IN RouterOS v6rc3
I have found a solution:
/lcd set backlight-timeout=never
/system leds set 0 type=interface-status interface=ether4 leds=lcdNow, when I turn my computer on (computer is connected to ether4) LCD backlight turns on, also. When I turn off my computer, LCD also goes off.
Ah, the simple pleasures in life and that sense of accomplishment when something just… works ![]()
Funny, you have digged the thread that is one year old, and everything has changed since then.
Now it works in different way:
/lcd backlight state=on
Thank you Mikrotik for adding mentioned option. ![]()
Thanks, this really helps
