Turning a wAP ac LTE Kit into a wAP LR2 Kit
I have an old wAP ac LTE Kit with an LTE modem which I would like to turn into a LoRaWAN gateway on 868MHz for private usage. The LTE modem was just used for a short time as an intermediary solution, so I don’t need it anymore.
I think I can just buy the R11e-LR8, rip out the LTE modem and stuff this card into it, right? What about the antennas? The LTE kit obviously came with a bunch of LTE antennas and according to the specs, band 5 and 8 which are supported by the LTE modem are on 850MHz and 900MHz. Can I just reuse one of the already installed antennas and hook them up to the LoRa module?
