There are 2 Internet provider, the first primary, secondary backup channel.
First give a static ip, second have a internal ip from router. I need to configure fault tolerance by ping.
Try to make failover from http://wiki.mikrotik.com/wiki/Advanced_Routing_Failover_without_Scripting#Multiple_host_checking_per_Uplink, unfortunately did not get to make it work.
Try to use scripting in the same result.
My knowledge does not allow to make it by myself, can anyone help me?
