I’ve got two ac^3, both running 7.11.2 and upgraded with wifiwave2 same version: one runs very well, while the other runs only 2GHz. The 5GHz seems to correctly pass the csc phase, the Status page State is “running”, but no “running” neither on status line nor in the WiFi Wave2 summary (just MB flags activated instead of RSMB as it should do).
This is all expected I think — now arguably Mikrotik made some poor UI choices.
The “flag” shown in winbox does not go to “R” (running) until someone is connected. Confusingly that status “tab” uses a different definition for running (meaning it has a frequency assigned).
The “S” (slave) flag not appears suggest the wifi interface is not a bridge port – I suspect this part is a config error (unless you meant for it to NOT be in a bridge).
I’ve deleted the wifiwave2 package and rebooted; re-configured both wifi with legacy set, and they work flawlessy.
Indeed the config was the same of another ac^3 here, that works with wifiwave2 without any issue.
I guess there should be some difference between the 5GHz wifi chips used.
Here the serials:
E7290E875797 non-working one
E7290EF9025A working one
The WLAN driver then also has state= “detecting radar” , not “running AP”.
Increased CAC time in the band 5600-5650MHz from 60s to 10 minutes. Be aware of the C and e frequencies!
“Skip DFS channels= 10min CAC” if auto freq is used.
If one fiddles with “Country” , then client and AP could use different channel ranges.
Well, as I wrote earlier, no infos in log (wireless / debug), and the config was identical to the one of another ac^3, perfectly working.
It has been powered on almost 12 hrs without announcing the 5GHz SSID.
And once downgraded to legacy wireless, it works correctly.
Ac3 works with legacy wifi on 5GHz, so no HW problem.
Wifiwave2 works on ac3 ( personally I have at least 6 devices showing that).
So it most likely is something in the info which for one reason or the other you refuse to share.
Show your config of the failing device !
Or solve it on your own…
Your choice.
No, auto did the same.
About country, tried even etsi or Italy or nothing: no 5GHz. Sometimes the channel selection message appears for 1 minute as it should do, but no 5GHz as well.
Anyway, it should be some hardware issue, or maybe the wifi chip has been changed across production batches and wifiwave2 doesn’t fit properly.
“add frequency=5180,5260,5500 name=ch-5g width=20/40/80mhz” and no country set will default to FCC region.
But should not be a problem if the regualted frequencies are correct in ROS. Check with “interface/wifiwave2/radio/print detail” ?
As in https://help.mikrotik.com/docs/display/ROS/WifiWave2#radios
Hmmmm WLAN1 and WLAN2 connected (port) to the bridge, but not available anymore as wifiwave2 is loaded, and wifi1 or wifi2 are not port to the bridge
DHCP will not work then, clients will disconnect.
Be accountable. You asked for help.
People said to help we need to see X and Y.
You didnt comply.
Yes it was your will to be non-compliant.
Be accountable.
Glad you finally “saw the light” as it was clear without cooperation you were going to lose assistance.
With that answer you’ll looking for a flame. I’ll not go ahead with that.
Simply you’re glad that I’ve “seen the light”, so you guess I’ve got a solution by posting the config.
So, no solution arised.
But with some difference to your aggressive behaviour, I accept to have somewhat failing device, I’ll not upgrade it to wifiwave2 and stop.
No solution? Okay, I accept and agree.
My scope is to solve, not to fight.
