two adsl modem for more bandwidth?
is this possible?
yes this is posible
use search in this forum and you will find how to do this.
http://wiki.mikrotik.com/wiki/Routing
is this really speed up my internet connection?
Yes, it will.
it’s not working … i have two dsl 1 is 384kbps and 2 is 512kbps there not combining
http://www.catb.org/~esr/faqs/smart-questions.html
Hello, ( first sorry, my english is not 100% ).
I have same problem, I am trying to use 2 adsl lines ( ether2 & ether3 ).
I did this http://wiki.mikrotik.com/wiki/Load_Balancing
And because the adsl lines assigns Dynamic Ip´s, I have added static IP to the ether2 and ether3 cards.
example:
ether1: 192.168.0.1
ether2: dyn.am.ic.ip1
ether2: 10.111.0.2
ether3: dyn.am.ic.ip2
ether3: 10.112.0.2
I did a traceroute from a computer in the lan side and it reachs one of these static addresses.
is possible to use Bonding instead of this method?
Do I have to add a Masquerade between the Dynamic Ip and Static IP? or a bridge?
I need to use both lines at the same time and if one line fails the other will asume all the load. I saw the different types of Bonding and I think bonding XOR is the right one for my needs.
Can someone help me to find the right configuration for me?
The Lan side will use 4 Ip´s maximum, and I have already setup the dhcp server.
Thanks in advance,
Gilberto
Hi again,
Well, I did it, but not using DHCP Client. And this is not the best way. Maybe I could upload a new firmware to the adsl modems and use them as routers. Right now, 2 linux boxes are the routers and giving me the Fixed IP number. But I think there could be a way to use Dynamic Ip from the ADSL line. Anyone could help me please?
It works, but i will be better if I could use Dynamic Ip directly. isn’t it?
Thanks in advance.
Gilberto Mehtar
from Venezuela.
:slight_smile:
