I state that I am VERY beginner.
I need a following configuration:
I have two networks, the first one generated by a 4G router to a private APN which requires a specific DNS and creates a “VPN”.
With this router I am therefore connected to an intranet, in which using a remote desktop on my PC I connect to the server on the intranet.
I can also use a browser to use the internet by setting the intranet proxy.
I would like to reach my PC from the outside using another ADSL connection with existing static IP.
I would like to reach it for example with TEAMVIEWER, and then connect with the RDP to the intranet server using the 4G connection.
The Routerboard will then have two WANs with two GW and a LAN where the PC is connected.
Is it possible to do this?
Thank you
It depends on what kind of beginners you are. If you’re willing to learn, everything is possible.
The simplest case would be if ADSL can be primary connection and 4G would be used only to access specific subnet(s). You’d simply configure router for one connection (ADSL) and you’d add 4G, but without default gateway, only with route(s) to specific subnet(s).
If 4G should be primary and ADSL only for remote access to PC, it would be regular dual-WAN config. Example of that is https://wiki.mikrotik.com/wiki/Manual:PCC. It’s mainly about load balancing, but when you skip the two rules with per-connection-classifier, it gives you basic dual-WAN config where you can route traffic to one connection or the other, router can be accesses from both connections, also port forwarding will work, basically everything you could need.
The rest is about various details, static or dynamic addresses that might need some tweaking, etc. The important thing is to try. If you get stuck, either ask about specific problem, of search the forum, everything has been done million times.
The routing part is easy - if I understand your case right, you simply need your mobile connection to be used only for access to the IP addresses of your intranet and the ADSL connection to be used for the rest, which is easily provided by configuring the mobile connection to add a default route with a high value of distance or not add it at all (depending whether it is a router connected using Ethernet or a 3G/4G modem connected to the Mikrotik), and manually add route(s) to the intranet subnet(s) via that gateway; more precise (longer) prefixes always have precedence over wider (shorter) prefixes, so packets towards the intranet will choose the manually added routes while packets to other destinations will take the default route with lower distance value, i.e. the one via ADSL.
I would like to use the 4G connection only for the intranet.
As I wrote, unfortunately I don’t know how to do it, I don’t know how to set the routing rules.
You can help me, if you want in MP I am willing to pay to solve this problem.
Thank you in advance
through a router (not mikrotik) with a sim inside
In the MK I have connected:
ETH1 from router with SIM 4G
ETH2 from router MK with ADSL and configured in client DHCP
ETH3 to PC
The 4G router also provides you with IP configuration (your address , default gateway, DNC) using DHCP or you must configure it statically if you connect your laptop directly to the 4G router?
Yes dhcp can be configured, the router is TELTONIKA RUT950
but if I configure it in dhcp, I still have to put the dns manual if it doesn’t connect to the intranet
That’s not the point, the point was whether you know the IP subnet and gateway to use and can configure them manually, and whether you know the DNS server address and all the subnets which represent the intranet.
What you need to do is to add the IP address on ether1 manually with the proper mask, and add a route or routes towards the intranet subnets via the 4G router’s IP address as a gateway. This makes it possible for your PC to connect there, but it does not resolve the DNS part. I was asking regarding DHCP because it sounded more likely to me and was about to tell you how to change /ip dhcp-client settings to get the information from there without interfering with the ADSL connection; as you apparently know the information (your IP, netmask, gateway IP, DNS server IP) already, this part is not necessary.
So you’ll end up with one default route provided by the DHCP client on ether2, and one or more routes added manually, with dst-address matching the intranet subnet(s) and the IP address of the 4G modem as gateway.
Then, you’ll need to adapt @Sob’s instruction for DNS redirection as mentioned above to your needs - to keep it simple, create one layer7-protocol row per each domain suffix representing the intranet, and one action=dst-nat rule per each such regexp, rather than composing a complex regexp covering all the domain suffixes.
OK, what DOES work for you? If you disable ether2, make 192.168.50.1 the gateway of a manually added route with dst-address=0.0.0.0/0 and distance=2, and change the DNS server from 8.8.8.8 to the intranet one, can the PC connect to intranet? Don’t do this remotely, you’d cut your access over ether2.
You’ve done exactly what I’ve asked you to do, but I haven’t realized that you probably never tried this before. So do also /ip firewall nat print where (!dynamic); /ip firewall nat add chain=srcnat action=masquerade out-interface=ether1 place-before=0. After this step the PC should get to intranet. If not, something must be wrong with the IP configuration of ether1.
the “place-before = 0” command gives me an error does not exist.
However it works the pc connects to the intranet.
on MK I configured a DHCP server on the ETH3 and the pc is connected to the ETH3 (with the network card configured in DHC mode including the DNS)
The first step was done
Yes, it was giving an error because that table was completely empty.
Now we know that intranet works. Given your other settings, I’d say it is safe to change the dst-address=0.0.0.0/0 in your manually added route to dst-address=10.0.0.0/8 and its distance to 1, it should still work - try it.
Next, after a while of working with the intranet, do /ip dns cache print and identify items which include the company name, as DNS queries for these items should be sent to the intranet DNS while the rest should be sent to the public DNS server. The items should be something like xxx.yourcompanyname.it or xxx.yourcompanyname or xxx.intranet and the IP address associated to them should start with 10.. It depends on how the administrator has set it, there is no generic rule, you have to check. The goal is to find the string which is common for the intranet servers’ domain names and let the layer7-protocol rule match on that string.
Can I give Sindy a patience award. You continually impress me man!!
Somebody close to him buy him a good meal and a hearty beer! Assuming its a guy, if not, then an excellent meal and classy white wine.
I also think he is very patient, but it is thanks to him that people like me will have the chance to grow.
As for good wine here from Italy there is plenty of it just tell me where I have to send it !!!
Ok, changing with 10.0.0.0/8 is still fine.
From the cache
/ ip dns cache print
I still don’t see anything, however the domain name I know.
if from the pc I ping the PC of the intranet network to which I should connect via RDP the ip that I get can go well?
Well, as you’ve mentioned that the DNS is necessary for intranet access to work, I’ve concluded you really need it because you maybe run some thick clients (applications) which refer to domain names they don’t show you. If you can RDP to a known IP address in the intranet, there is no need to do anything with the DNS redirection which makes the whole task about 17 times easier
What makes me quite scared is that your Mikrotik was connected to the internet with no firewall rules at all. I’ve initially thought that you removed the firewall rules from the configuration you’ve posted to make it smaller, but as the adding of the srcnat rule has shown, there are really none. So I suppose the ADSL router you use for regular internet connection does NAT and no port forwarding, and no access from WAN side is permitted on it, but I would still recommend to use the default firewall rules modified for your interface roles (i.e. set ether2 as the only member of interface list WAN) also on the Mikrotik as you never know how well secured the ADSL router is. Especially if the “filth from the net” can get to your company’s network via your setup if it bites its way through the ADSL router and squats on your Tik (not that something couldn’t squat on your PC and get to the Tik from there, or attack the intranet machines directly - the crypto-currencies are rising again so all the bad guys want your processor resources ).
Leaving the scary side of life aside for a while: if it is enough for you that the PC at ether3 of your Tik stays on and accepts incoming TeamViewer connections, and that you can RDP from there to an IP in the intranet, all you have to do right now is to add another masquerade rule which will be exactly the same like the one you’ve added before but for ether2 (the ADSL WAN), set the DNS server of the Tik back to 8.8.8.8, and enable the ether2 again.
