Hi, I can’t find the correct settings for the following situation:
I have two connections with Equinix-SP4, the government gave me the same /20 subnet for IPv4 and the same /64 subnet for IPv6, first access (functional) vlan3xx1 with IP range: 192.168.4.5/20 for IPv4 and vlan3xx2 with range of IP: fd80:12f8::4:5/64 for IPv6, second access (in activation) vlan2xx5 with IP range: 192.168.5.8/20 for IPv4 and vlan2xx6 with IP range: fd80:12f8::5:8 /64 for IPv6. As soon as I activate the vlans of the active link, the active bgp sessions on the first peer drop, I saw something about vrf, could someone please give an example of how the settings should be for operation? Here I tested placing the vlans of each connection in a separate vrf, and in connection in the peer session I set the vrfs, however all destinations coming from that peer stop working.
