Two DHCP ISPs, Recursive Routing but Firewall Test Filter Not Working
Apologies if this should be in the ‘Beginner Basics’ group; Admin, Please move if necessary.
Background
RB4011, Router OS v7.12rc2
WinBox v3.4 64bit
I have two DHCP ISPs, LTE Primary, VDSL Failover, both presenting public IP addresses. The FTTC VDSL requires IPv6 MER (MAC Encapsulated Routing) authentication but currently I only use the IPv4 address.
The configuration is built off the default configuration of the RB4011.
I have setup Recursive Routing broadly with the help of Wilmer Almazan / The Network Trip from this helpful video: https://www.youtube.com/watch?v=eTmpBAAW_pQ
At 18:20 in the video Wilmer demonstrates testing the failover by introducing a firewall filter to drop traffic exiting ISP1’s Internet interface.
I have tried to replicate this function in my RB4011 firewall but without success because, presumably, I still have an Internet connection to & via my ISP? Therefore the failover does not occur. If I disable the Ethernet 10 interface to my LTE modem (RBM33G in passthrough with RM502Q-AE) then failover does occur.
However, I have tried to filter traffic to:
Chain: forward, Dst. Address: 1.0.0.1, Out. Interface: ether10-LTE, Action: Drop
but it doesn’t failover. I have tried the rule at the top and bottom of the firewall Filter Rules but without success.
Is what I’m trying to do possible?
I’m making a big assumption, of course, that my configuration, which through the learning process I have laboured over, is correct?
(I’m planning to add Policy Based Routing to, hence the toLTE & toVDSL routing table entries - but one step at a time.)
Any kind and helpful responses will be welcomed as I’m keen to learn.
Thank you in anticipation.
My ‘privatised’ config attached.
How do network professionals, without control of their ISP(s) test their recursive routing failover?
# 2023-10-26 16:11:01 by RouterOS 7.12rc2
# software id = <my value>
# model = RB4011iGS+
# serial number = <my serial #>
add admin-mac=<my MAC address> auto-mac=no comment=defconf name=bridge
set [ find default-name=ether10 ] name=ether10-LTE
set [ find default-name=sfp-sfpplus1 ] auto-negotiation=no name=\
    sfp-sfpplus1-VDSL speed=100M-baseT-full
/interface wireguard
add listen-port=13231 mtu=1420 name=HomeNetWG
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip dhcp-client option
add code=79 name=client_duid79 value=<my value>
add name=dhcp ranges=192.168.1.53-192.168.1.253
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
/ipv6 dhcp-client option
add code=61 name=clientid_duid61 value=<my value>
add code=61 name=clientid value=<my value>
/port
set 0 name=serial0
set 1 name=serial1
/routing table
add disabled=no fib name=toLTE
add disabled=no fib name=toVDSL
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge interface=ether1
add interface=sfp-sfpplus1-VDSL list=WAN
add interface=ether10-LTE list=WAN
/interface wireguard peers
add allowed-address=192.168.10.2/32 interface=HomeNetWG public-key=<my value>
add address=192.168.1.254/24 comment=defconf interface=bridge network=\
    192.168.1.0
add address=192.168.10.1/24 interface=HayloftNetWG network=192.168.10.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf default-route-distance=2 !dhcp-options interface=\
    sfp-sfpplus1-VDSL script="# Recursive via sfp-sfpplus1-VDSL\r\
    \n\r\
    \n:if (\$bound=1) do={/ip route set [find where dst-address=4.2.2.2/32 and\
    \_comment=\"Recursive via sfp-sfpplus1-VDSL\" ] gateway=( \$\"gateway-addr\
    ess\" . \"%sfp-sfpplus1-VDSL\" ) }\r\
    \n\r\
    \n\r\
    \n# :if (\$bound=1) do={/ip route set [find where dst-address=0.0.0.0/0 an\
    d comment=\"sfp-sfpplus1-VDSL\" ] gateway=( \$\"gateway-address\" . \"%sfp\
    -sfpplus1-VDSL\" ) }" use-peer-dns=no
add !dhcp-options interface=ether10-LTE script="# Recursive via ether10-LTE\r\
    \n\r\
    \n:if (\$bound=1) do={/ip route set [find where dst-address=1.0.0.1/32 and\
    \_comment=\"Recursive via ether10-LTE\" ] gateway=( \$\"gateway-address\" \
    . \"%ether10-LTE\" ) }\r\
    \n\r\
    d comment=\"ether10-LTE\" ] gateway=( \$\"gateway-address\" . \"%ether10-L\
    TE\" ) }" use-peer-dns=no
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.254 gateway=\
    192.168.1.254 netmask=24
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.1.254 comment=defconf name=router.lan
    "For Test Only - Drop Traffic out of sfp-sfpplus1-VDSL" disabled=yes \
    dst-address=4.2.2.2 dst-address-list="" out-interface=sfp-sfpplus1-VDSL
    "For Test Only - Drop Traffic out of ether10-LTE" disabled=yes \
    dst-address=1.0.0.1 out-interface=ether10-LTE
add action=accept chain=input comment="Allow WireGuard" dst-port=13231 \
    protocol=udp
add action=accept chain=input comment="Allow WireGuard traffic" src-address=\
    192.168.10.0/24
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add check-gateway=ping comment=ether10-LTE disabled=no distance=1 \
    dst-address=0.0.0.0/0 gateway=1.0.0.1 pref-src=0.0.0.0 routing-table=main \
    scope=30 suppress-hw-offload=no target-scope=11
add check-gateway=ping comment=sfp-sfpplus1-VDSL disabled=no distance=2 \
    dst-address=0.0.0.0/0 gateway=4.2.2.2 pref-src=0.0.0.0 routing-table=main \
add comment="Recursive via ether10-LTE" disabled=no distance=1 dst-address=\
    1.0.0.1/32 gateway=94.197.30.22%ether10-LTE pref-src=0.0.0.0 \
    routing-table=main scope=10 suppress-hw-offload=no target-scope=10
add comment="Recursive via sfp-sfpplus1-VDSL" disabled=no distance=1 \
    dst-address=4.2.2.2/32 gateway=94.1.176.1%sfp-sfpplus1-VDSL pref-src=\
    0.0.0.0 routing-table=main scope=10 suppress-hw-offload=no target-scope=\
    10
/ipv6 dhcp-client
add add-default-route=yes dhcp-options=client_duid79,clientid_duid61,clientid \
    dhcp-options=client_duid79,clientid_duid61,clientid interface=\
    sfp-sfpplus1-VDSL pool-name=IPv6 pool-prefix-length=56 request=prefix
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/London
/system identity
set name=Router_RB4011_PoE24v
/system note
set show-at-login=no
/system scheduler
add disabled=yes interval=1h30m name=sfp-sfpplus1-VDSL_Ping&Release on-event=\
    "/system script run sfp-sfpplus1-VDSL_Ping&Release" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-date=2023-10-22 start-time=21:50:00
add disabled=yes interval=1h30m name=ether10-LTE_Ping&Release on-event=\
    "/system script run ether10-LTE_Ping&Release" policy=\
    start-date=2023-10-23 start-time=17:00:00
/system script
add dont-require-permissions=no name=sfp-sfpplus1-VDSL_Ping&Release owner=\
    admin policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":\
    if ( [/ping 8.8.8.8 interface=sfp-sfpplus1-VDSL count=10 ] = 0 ) do={/ip d\
    hcp-client release sfp-sfpplus1-VDSL}"
add dont-require-permissions=no name=ether10-LTE_Ping&Release owner=admin \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source=":if ( [/ping 8.8.8.8 interface=ether10-LTE count=10 ] = 0 ) do={/i\
    p dhcp-client release ether10-LTE}"
/tool mac-server
/tool mac-server mac-winbox
The routing table’s check-gateway=ping check isn’t covered by the “forward” (that for traffic OFF the router, like a desktop/smartphone). Traffic generated by the router, like that of check-gateway=ping, would be “input” traffic.
OK, thanks @Amm0, that makes sense to me.
I have successfully tested the drop filter rule on both recursive routes, 1.0.0.1 & 4.2.2.2, from my laptop on the network using the forward chain.
Thanks again, I can now be fairly confident that if the recursive route isn’t reachable the router will failover from WAN to the other.
Regards,
Steve
