Two DHCP Servers inside a Network
It has happened a couple of times when inside a network there
are two dhcp servers, one of the RouterOS and another one.
Now the second is causing a lot of trouble since it gives
wrong IP addresses and gateways to the computers.
Any idea how to avoid it using Mikrotik features?
set one as authoritative=yes
Thanks Janisk :slight_smile:
I’ll see if this works next time
