Hi there,
Iam using the rb 600 and iam running two hotspots servers, the first one is on wlan and the second on eth1, my question
is if could the first server working with the remote userman and the second with the local one.
Now is working with the first on the top list of radius servers
Thank you
Yes, it is possible.
HotSpot is using local /ip hotspot user menu at first and only then RADIUS server is contacted.
Add local users to /ip hotspot user menu and specify HotSpot server name for them.
Configure RADIUS configuration for the second HotSpot server, as there is no any user in local database, RADIUS server will be contacted for second user.
Thank you very much Sergejs!
