Two DVRs
Hi
We have two DVR (one DVR, one HVR) onsite and I can only get one to work at a time via our Mikrotik RB. I have duplicated the NAT rules and amended the settings so they work for each system, but when I have both plugged in, only one is accessible.
Is there a way to have the two systems accessible via the LAN and WAN, or will I need a different router?
TIA.
Andrew.
Did the DVRs have different ip address?
Post an /export hide-sensitive of your router
DVR 1 = 192.168.1.140 ports 888 and 9000 and 554
HVR 1 = 192.168.1.141 ports 8888 and 9100 and 554
both have masq rules for the subnet 192.168.1.0/24 to their IPs
Both have DNSNAT rules for their ports for the external IP to each internal IP
I’ll try and get an export off in a few mins.
if you are using the same public ip you have an issue with 554 port because is duplicated on both dvrs
Change the rstp port on the second DVR to 555 and you will be set
