Two errors - invalid value for argument address and Destination host unreachable
Error 1:
invalid value for argument address:
invalid value of mac-address, mac address required
invalid value for argument ipv6-address
while resolving ip-address: could not get answer from dns server
Error 2: when try to ping gateway IP:
Destination host unreachable (from command-line Ping)
feb/09/2020 18:17:09 by RouterOS 6.46.3
software id = L3GW-9M2T
model = CRS354-48G-4S+2Q+
serial number = XX
add admin-mac=90:61:XX:XX:XX:39 ageing-time=15s auto-mac=no comment=defconf
name=bridge
set [ find default-name=ether1 ] mac-address=90:61:XX:XX:XX:39
set [ find default-name=ether49 ] mac-address=90:61:XX:XX:XX:39
add comment=defconf name=WAN
add comment=defconf name=LAN
add bridge=bridge interface=ether1
add bridge=bridge interface=ether5
add bridge=bridge interface=ether6
add bridge=bridge interface=ether7
add bridge=bridge interface=ether8
/interface detect-internet
set detect-interface-list=all internet-interface-list=WAN lan-interface-list=
LAN wan-interface-list=WAN
add comment=WAN interface=ether49 list=WAN
add address=10.0.0.1/28 comment=ip interface=bridge network=10.0.0.0
add address=111.XX.67.246/28 comment=WLAN interface=ether1 network=
111.XX.67.240
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
add action=masquerade chain=srcnat ipsec-policy=out,none
add check-gateway=ping distance=1 gateway=111.XX.67.241 pref-src=10.0.0.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox disabled=yes
set api-ssl disabled=yes
/system clock
/system routerboard settings
set boot-os=router-os
/tool mac-server
/tool mac-server mac-winbox
Any ideas what I should set?
IP 111.XX.67.246/28 - 90:61:XX:XX:XX:39
Gateway: 111.XX.67.241
I don’t think you can set same MAC to multiple interfaces and you try to set the same MAC on 3 interfaces … why do you want it that way?
Thank you for your feedback.
Okay - take 2:
I changed interface-bridge to .40, ether49 to .41.
Still no internet. what gives?
serial number = XX
add admin-mac=90:61:XX:XX:XX:40 ageing-time=15s auto-mac=no comment=defconf
name=bridge
set [ find default-name=ether1 ] mac-address=90:61:XX:XX:XX:41
111.XX.67.240
/ip service
/system clock
/tool mac-server
I’m trying to set the IP address so the “Mac ID” can be recognized by the router that’s external. The external router binds by Mac ID.
Your setup is highly fuzzy:
  • you have ether49 stand-alone port (and thus suitable for routed traffic) and it’s member of WAN interface list. But yet you set WAN IP on ether1
  • you have IP address set on ether1, which is member pirt of bridge (which has set a different IP address). IP address should always be set on bridge interface, never on slave interfaces
  • I suggest you to disable detect-internet … most of times it doesn’t do anything and occasionally it messes with proper operations
And last (but not least importantly): your CRS has no firewall set and is thus highly susceptible to any malicious attacks. Therefore I highly suggest you to set some good rules before you manage to make internet working. SOHO line of devices comes with decent firewall as default, but I’m not sure if CRS has any (probably not as it’s a) pro-line and b) switch with low-capacity IP functionality) … You can find default firewall filter setup on this forum, I’ve posted it more than once.
okay, take 4.
disabled ether1 and moved them all to ether39.
feb/09/2020 19:37:01 by RouterOS 6.46.3
add admin-mac=90:XX:XX:XX:XX:40 ageing-time=15s auto-mac=no comment=defconf
igmp-snooping=yes name=bridge
set [ find default-name=ether49 ] mac-address=90:XX:XX:XX:XX:39
/ip hotspot profile
add address=10.0.0.1 comment=ip interface=bridge network=10.0.0.0
add address=111.XX.XX.246/28 comment=WLAN interface=ether49 network=
111.XX.67.240
add check-gateway=arp distance=1 gateway=111.XX.67.241
/ip service
What's wrong now?
Okay, I'll get some firewall settings.
You keep mentioning different WAN ports (latest is ether39) while WAN config is on ether49 …
And even when WAN starts to work, you won’t have internet access from LAN devices, you need to set up NAT. So really find some good default firewall settings (find some recent post on this forum) before you fuss too much about other setup.
