CCR already has two fans but only one of them spinning - main or auxiliary. I do wish two fans spinning simultaneously.
Is there a way to do so via RouterOS?
Same problem with 1100AHX2.
I joined the two fans with a cable and plugged it into main.
Now both works in the same time.
Just wondering if this is intended or a malfunction.
Again, if you read the provided documentation, it should be clear that this is intended.
What are the odds that you would buy and receive two devices that are both vastly different models (RB1100AHx2, CCR1016) with vastly different architectures and that they would both happen to have the same kind of defect or malfunction?
If System Health shows only one “Active Fan” and also allows you to select only one fan to use, why would you think that both can be active simultaneously?
You can argue about whether you think this is a good design or not, or whether you like the design or don’t like it, but it seems pretty clear to me what the designers intended.
There is no need to run both at the same time. The unit gets good cooling with one fan. The second fan is there only as backup, if the first fails. Try to stop it with a pencil, and you will see how this works.
You just need to move second fan connector from header 2 to header 3 counting from Left to right Then both fans will be on.
if it on header 2 it will work as backup.
