Hi, because my last post was without answer will try ask a bit simple ![]()
I Have “router2” with two gateways
- dynamic from OSPF from “router 1”
- static on eth1 on “router 2”
when everything works dynamic gateway is used
DST-ADDRESS GATEWAY-STATE GATEWAY DISTANCE PACKETMARK
0 S 0.0.0.0/0 reachable 212.71.166.1 200
1 A S 0.0.0.0/0 reachable 212.71.166.1 150 BACKUP
2 ADo 0.0.0.0/0 reachable 192.168.30.1 110
when "router 1 " is down static gateway is correctly used (0 S 0.0.0.0/0) as default gateway in network , but when “router1” is up again, default route (2 ADo 0.0.0.0/0 )from it is not on “router 2” I must disable static routes on “router2” and then dynamic (2 ADo 0.0.0.0/0 ) is shown. then i can enable static default routes again .
Please is there anybody who knows how to make it work without enabling/disabling interface ?
Thanks a lot
Jonescz
