Two ISP connection fail over setting
I have two isp connection. i want to setup failover of those.
can anyone give me simple way to do it ?
Have you searched for an answer here? It’s already described several times around.
well, i have googled and i found many script, but all are confusing with me. just i wanted if anyone can give me one way to do it and follow the link.
if you can do it for me will be very very helpful please.
It is not so easy to write it all on the mobile phone. I am thinking of writing one comprehensive guide how to make the dual (generally multiple) wan failover based on routing. But I didn’t have enough time to sit at the computer and dedicate the time to prepair the guide yet.
thanks for your concern. even if you can refer any link that also oke.
my ask is
two ISP
one primary
one backup failover
