two ISP on a CCRS
Hi guys, it´s been a long time since I visited last time the forum and I see that a lot has changed! congrats on every improvements for the mikrotik crew.
I have a few questions about the CCRS and the switch OS
I have two ISPs and would like to use the CCRS to connect ports 2 through 9 to ISP1 and ports 10 through 18 to ISP 2. On ports 2 - 9 there would be DHCP1 server (192.168.1.0/24 network for example) and on ports 10 - 18 DHCP2 (192.168.2.0/24 network for example) and would like to reach both LANs. Would this be possible? Did I explain myself well enough?
Best regards,
Ignacio
Hi if the Port 1 will be for isp 1 witch Port will be for isp 2?
Gesendet von iPhone mit Tapatalk
If u just want to resch Networks lets say 192.168.1.100 to reach 192.168.2.100 or other way , you can do this 2 Regel in ip Route dst addresse 192.168.2.0/24 Gateway is 192.168.1.1 if 192.168.1.1 is your LAN Gateway and other one ip Route dst addresse 192.168.1.0/24 Gateway 192.168.2.1 if 2.1 is your Second LAN Gateway .
Best regards
Ok so just configured it as you wich and put this two regel under ip Route and u will be able to Ping from 192.168.2.0/24 to 1.0/24 or otherwise
If you Need configuration Setup i will help you with it
You Are always welcome you send me what you exactly want and i send you config file just Upload it and you Are ready to Go
