Hello.
I have a few Mikrotik RB2011UiAS-RM in remote offices.
One of them has a two ISP. Each ISP provides inet thru PPPoE connection.
When ISP#1 and ISP#2 connected, its able to connect to router thru ISP, which have default route with smaller distance.
I have setup mangle rules and route marks like show below, but have no luck with connect to router thru link with bigger distance. But the same “best practice” configuration of mangle rules and route marks for two uplinks thru usual Ethernet to different ISPs works in other offices fine.
Why PPPoE clients (mean “PPPoE interfaces”) in RB2011 does not work with mangle rules ?
Here is my setup:
[vadeg@colocation1] /interface pppoe-client> print
0 R name="pppoe-ISP1" max-mtu=1480 max-mru=1480 mrru=1600 interface=FE7-ISP1
user="v1" password="123456" profile=default keepalive-timeout=60
service-name="" ac-name="" add-default-route=no dial-on-demand=no
use-peer-dns=yes allow=pap,chap,mschap1,mschap2
1 R name="pppoe-ISP2" max-mtu=1480 max-mru=1480 mrru=1600 interface=FE6-ISP2
user="v2" password="123456" profile=default
keepalive-timeout=60 service-name="" ac-name="" add-default-route=no
dial-on-demand=no use-peer-dns=yes allow=pap,chap,mschap1,mschap2
[vadeg@colocation] /ip route> export
# jul/27/2015 19:22:51 by RouterOS 6.30.2
# software id = FFR3-5FMI
add check-gateway=ping comment=ISP1_FIB1_GW distance=1 gateway=pppoe-ISP1 pref-src=\
1.1.1.1 routing-mark=ISP1-GW-R
add check-gateway=ping comment=ISP2_FIB2_GW distance=1 gateway=pppoe-ISP2 pref-src=\
2.2.2.2 routing-mark=ISP2-GW-R
add check-gateway=ping distance=1 gateway=pppoe-ISP1 pref-src=1.1.1.1
add check-gateway=ping distance=2 gateway=pppoe-ISP2 pref-src=2.2.2.2
/ip route rule add disabled=yes interface=pppoe-ISP1 routing-mark=ISP2-GW-R src-address=\
2.2.2.2/32 table=ISP2-GW-R
[vadeg@colocation] /ip firewall mangle> export
# jul/27/2015 19:32:46 by RouterOS 6.30.2
/ip firewall mangle
add action=mark-connection chain=prerouting dst-address=2.2.2.2in-interface=\
pppoe-ISP2 log-prefix=ISP2_CONN new-connection-mark=ISP2_CONN passthrough=no
add action=mark-connection chain=prerouting dst-address=1.1.1.1 in-interface=\
pppoe-ISP1 new-connection-mark=ISP1_CONN
add action=mark-routing chain=output connection-mark=ISP2_CONN log-prefix=ISP2-MARK \
new-routing-mark=ISP2-GW-R out-interface=pppoe-ISP2 passthrough=no
add action=mark-routing chain=output connection-mark=ISP1_CONN new-routing-mark=\
ISP1-GW-R out-interface=pppoe-ISP1 passthrough=no
