Two ISP with one acting as failover
I have two ISPs, the primary ISP on eth1 (Modem is bridged) and failover ISP on eth2. The failover ISP is in Running(R) state and primary is in Running Slave (RS) state. Currently we had an issue with primary ISP modem going out and just got it replaced and after a power cycle, the failover ISP is still active and eth1 is not being found. We have tested directly connected to the ISP modem and it’s working. We also have eth3 going to one of our switches (RS) that runs all of our servers and computers.
For this setup, when we go into Quick Set, should we select NAT? ANd since there is a bridge-network setup on this router, should Bridge all LAN Ports be checked? Should the port be changed from SFP1 to eth1? When we go straight to quick set, port shows SFP1 (Nothing is in sfp1).
Any suggestion on how to get this setup correctly would be helpful.
http://wiki.mikrotik.com/wiki/Advanced_Routing_Failover_without_Scripting
http://forum.mikrotik.com/t/script-dual-wan-load-balancing-with-fail-over/81881/1
Here you go… :slight_smile:
