Two ISP's
Hi all,
I’m trying to setup scheduled times to connect and disconnect pppoe connections. (two ISP’s)
  1. Weekdays from 6:00:00 till 17:59:50, interface pppoe-out1 (ISP1) must be used.
  2. Weekdays from 18:00:00 till 5:59:50, interface pppoe-out2 (ISP2) must be used.
  3. Weekends from Friday 17:59:50 until Monday 5:59:50, interface pppoe-out2 (ISP2) must be used
It’s easy enough to do this daily, but how would I get this to recognize weekends?
Thanks.
(note - still a noob, be gentle.)
I have this so far:
/system scheduler
add interval=1d name=peak on-event=start_peak policy=reboot,read,write,policy,test,password,sniff,sensitive start-date=aug/07/2014 start-time=06:00:00
add interval=1d name=offpeak on-event=start_offpeak policy=reboot,read,write,policy,test,password,sniff,sensitive start-date=aug/07/2014 start-time=18:00:00
add interval=1w name=week on-event=enable_switch policy=reboot,read,write,policy,test,password,sniff,sensitive start-date=aug/11/2014 start-time=00:00:00
add interval=1w name=weekend on-event=disable_switch policy= reboot,read,write,policy,test,password,sniff,sensitive start-date=aug/09/2014 start-time=00:00:00
/system script
add name=start_peak policy=reboot,read,write,policy,test,password,sniff,sensitive source=\
    "/interface pppoe-client disable pppoe-out2
     /interface pppoe-client enable pppoe-out1"
add name=start_offpeak policy=reboot,read,write,policy,test,password,sniff,sensitive source=\
    "/interface pppoe-client disable pppoe-out1
    /interface pppoe-client enable pppoe-out2"
add name=enable_switch policy=reboot,read,write,policy,test,password,sniff,sensitive source="/system scheduler enable [/system scheduler find name=peak] /system scheduler enable [/system scheduler find name=offpeak]"
add name=disable_switch policy=reboot,read,write,policy,test,password,sniff,sensitive source="/system scheduler disable [/system scheduler find name=peak] /system scheduler disable [/system scheduler find name=offpeak]"
For some reason the peak & off-peak are not triggering, the weekend ones did.
I have the exact same question. Have you been able to figure it out?
