Two issues with rb500
Issue 1:
I have two wireless cards installed. After startup it rarely finds both cards, most of the time finds one card (but not nessarly the same card), and once in a while finds neither card.
These are the athlos a/b/g cards that came with the unit. AR5211’s
Issue 2:
Once I get the unit to recognize a card I set it to 802.11a and try to connect to the network and it finds nothing. Switch to 802.11b (and switch antenna) and it works fine. I’ve checked the antenna and cabling already. Both the 802.11a and 802.11b singal are coming from the same tower, same distance away (.5 miles)
Other clients connect just fine to A or B.
