Hi, I have a problem with CAP lite
I open an IP adress of CAP, display standard webfig login. After type credentials, then display the new design login, I type credentials and display again old desigh login. Is cyclic.
How can I restore only old webfig?
Style of webfig is locked with ROS version on a particular device. If you alternately see old and new, then it’s web browser playing tricks on you (serving cached contents). Clear the cache and you’ll have consistent UI.
Of course, if you’re switching between different ROS drvices, you’ll see different webfig styles if different devices run different ROS versions.
That’s interesting. ROS is the same on all devices. I see the old webfig on two CAPs, and on one it switches by itself.
Browser caches contents on “per server” basis. It never uses cached item, obtained from one server, on page served by another server. So if you’re seeing mixed contents, you still have to clear browser’s cache.
