I do have a RB1200 with two public IP addresses on the WAN interface XX.YY.ZZ.110 and XX.YY.ZZ.235 (same /24 subnet). I use src-nat to map outgoing connections to the right public IP. (And dst-nat to map incomming public IP connections to the correct local IP).
server 1:
public IP: XX.YY.ZZ.110 local IP: 192.168.18.20
server 2:
public IP: XX.YY.ZZ.235 local IP: 192.168.18.10
The probles is that connections from server to server (email, telnet etc.) get: Connection refused, and users are not able to send email to each other (server to server). Should this not work?
set [ find default-name=ether1 ] name=ether1-WAN
set [ find default-name=ether2 ] name=ether2-LAN
add address=192.168.18.1/24 interface=ether2-LAN network=192.168.18.0
add address=XX.YY.ZZ.235/24 interface=ether1-WAN network=XX.YY.ZZ.0
add address=XX.YY.ZZ.110/24 interface=ether1-WAN network=XX.YY.ZZ.0
add action=drop chain=input comment=“Drop input WAN-IP src-add” disabled=yes in-interface=ether1-WAN src-address=XX.YY.ZZ.235
add action=drop chain=input comment=“Drop input invalid connections” connection-state=invalid in-interface=ether1-WAN
add action=drop chain=forward comment=“Drop forward invalid connections” connection-state=invalid in-interface=ether1-WAN
add chain=input comment=“Accept Winbox” dst-port=8291 in-interface=ether1-WAN protocol=tcp
add chain=forward comment=“Accept fwd FTP” dst-port=21 in-interface=ether1-WAN protocol=tcp
add chain=forward comment=“Accept fwd SSH” dst-port=22 in-interface=ether1-WAN protocol=tcp
add chain=forward comment=“Accept fwd SMTP” dst-port=25 in-interface=ether1-WAN protocol=tcp
add chain=forward comment=“Accept fwd HTTP” dst-port=80 in-interface=ether1-WAN protocol=tcp
add chain=forward comment=“Accept fwd HTTPS” dst-port=443 in-interface=ether1-WAN protocol=tcp
add chain=forward comment=“Accept fwd POP” dst-port=110 in-interface=ether1-WAN protocol=tcp
add chain=forward comment=“Accept fwd IMAP” dst-port=143 in-interface=ether1-WAN protocol=tcp
add chain=forward comment=“Accept fwd IMAP SSL” dst-port=993 in-interface=ether1-WAN protocol=tcp
add chain=forward comment=“Accept fwd SNMP” dst-port=161 in-interface=ether1-WAN protocol=udp
add chain=forward comment=“Accept fwd SMTP submission” dst-port=587 in-interface=ether1-WAN protocol=tcp
add chain=forward comment=“Accept fwd SMTP SSL” dst-port=465 in-interface=ether1-WAN protocol=tcp
add chain=forward comment=“Accept fwd ISPConfig control panel” dst-port=8080 in-interface=ether1-WAN protocol=tcp
add chain=forward comment=“Accept fwd Sieve” dst-port=4190 protocol=tcp
add chain=input comment=“Accept fwd ICMP” in-interface=ether1-WAN protocol=icmp
add chain=input comment=“Accept input established connections” connection-state=established
add chain=input comment=“Accept input related connections” connection-state=related
add chain=forward comment=“Accept fwd established connections” connection-state=established limit=100,500
add chain=forward comment=“Accept fwd related connections” connection-state=related
add action=log chain=input disabled=yes in-interface=ether1-WAN log-prefix=drop_
add action=drop chain=input in-interface=ether1-WAN
add action=src-nat chain=srcnat comment=“srcnat XX.YY.ZZ.235 server 2” out-interface=ether1-WAN src-address=192.168.18.10 to-addresses=XX.YY.ZZ.235
add action=src-nat chain=srcnat comment=“srcnat XX.YY.ZZ.110 server 1” out-interface=ether1-WAN src-address=192.168.18.20 to-addresses=XX.YY.ZZ.110
add action=dst-nat chain=dstnat comment=“server 2 FTP” dst-address=XX.YY.ZZ.235 dst-port=21 in-interface=ether1-WAN protocol=tcp to-addresses=192.168.18.10 to-ports=21
add action=dst-nat chain=dstnat comment=“server 2 SSH” dst-address=XX.YY.ZZ.235 dst-port=22 in-interface=ether1-WAN protocol=tcp src-address=AA.AA.AA.AA to-addresses=192.168.18.10 to-ports=22
add action=dst-nat chain=dstnat comment=“server 2 SMTP” dst-address=XX.YY.ZZ.235 dst-port=25 in-interface=ether1-WAN protocol=tcp to-addresses=192.168.18.10 to-ports=25
add action=dst-nat chain=dstnat comment=“server 2 HTTP” dst-address=XX.YY.ZZ.235 dst-port=80 in-interface=ether1-WAN protocol=tcp to-addresses=192.168.18.10 to-ports=80
add action=dst-nat chain=dstnat comment=“server 2 POP” dst-address=XX.YY.ZZ.235 dst-port=110 in-interface=ether1-WAN protocol=tcp to-addresses=192.168.18.10 to-ports=110
add action=dst-nat chain=dstnat comment=“server 2 IMAP” dst-address=XX.YY.ZZ.235 dst-port=143 in-interface=ether1-WAN protocol=tcp to-addresses=192.168.18.10 to-ports=143
add action=dst-nat chain=dstnat comment=“server 2 SNMP” dst-address=XX.YY.ZZ.235 dst-port=161 in-interface=ether1-WAN protocol=udp to-addresses=192.168.18.10 to-ports=161
add action=dst-nat chain=dstnat comment=“server 2 SMTP submission” dst-address=XX.YY.ZZ.235 dst-port=587 in-interface=ether1-WAN protocol=tcp to-addresses=192.168.18.10 to-ports=587
add action=dst-nat chain=dstnat comment=“server 2 Management” dst-address=XX.YY.ZZ.235 dst-port=8080 in-interface=ether1-WAN protocol=tcp to-addresses=192.168.18.10 to-ports=8080
add action=dst-nat chain=dstnat comment=“server 1 SSH” dst-address=XX.YY.ZZ.110 dst-port=22 in-interface=ether1-WAN protocol=tcp src-address=AA.AA.AA.AA src-port=“” to-addresses=192.168.18.20 to-ports=22
add action=dst-nat chain=dstnat comment=“server 1 SMTP” dst-address=XX.YY.ZZ.110 dst-port=25 in-interface=ether1-WAN protocol=tcp src-port=“” to-addresses=192.168.18.20 to-ports=25
add action=dst-nat chain=dstnat comment=“server 1 HTTP” dst-address=XX.YY.ZZ.110 dst-port=80 in-interface=ether1-WAN protocol=tcp src-port=“” to-addresses=192.168.18.20 to-ports=80
add action=dst-nat chain=dstnat comment=“server 1 POP” dst-address=XX.YY.ZZ.110 dst-port=110 in-interface=ether1-WAN protocol=tcp src-port=“” to-addresses=192.168.18.20 to-ports=110
add action=dst-nat chain=dstnat comment=“server 1 IMAP” dst-address=XX.YY.ZZ.110 dst-port=143 in-interface=ether1-WAN protocol=tcp src-port=“” to-addresses=192.168.18.20 to-ports=143
add action=dst-nat chain=dstnat comment=“server 1 SNMP” dst-address=XX.YY.ZZ.110 dst-port=161 in-interface=ether1-WAN protocol=udp src-port=“” to-addresses=192.168.18.20 to-ports=161
add action=dst-nat chain=dstnat comment=“server 1 HTTPS” dst-address=XX.YY.ZZ.110 dst-port=443 in-interface=ether1-WAN protocol=tcp src-port=“” to-addresses=192.168.18.20 to-ports=443
add action=dst-nat chain=dstnat comment=“server 1 SMTP SSL” dst-address=XX.YY.ZZ.110 dst-port=465 in-interface=ether1-WAN protocol=tcp src-port=“” to-addresses=192.168.18.20 to-ports=465
add action=dst-nat chain=dstnat comment=“server 1 SMTP submission” dst-address=XX.YY.ZZ.110 dst-port=587 in-interface=ether1-WAN protocol=tcp src-port=“” to-addresses=192.168.18.20 to-ports=587
add action=dst-nat chain=dstnat comment=“server 1 IMAP SSL” dst-address=XX.YY.ZZ.110 dst-port=993 in-interface=ether1-WAN protocol=tcp src-port=“” to-addresses=192.168.18.20 to-ports=993
add action=dst-nat chain=dstnat comment=“server 1 POP SSL” dst-address=XX.YY.ZZ.110 dst-port=995 in-interface=ether1-WAN protocol=tcp src-port=“” to-addresses=192.168.18.20 to-ports=995
add action=dst-nat chain=dstnat comment=“server 1 Sieve” dst-address=XX.YY.ZZ.110 dst-port=4190 in-interface=ether1-WAN protocol=tcp src-port=“” to-addresses=192.168.18.20 to-ports=4190
