Two mikrotik single network
Hi all,
I am trying to configure 2 different mikrotik for 2 different isps (say ispA and ispB) in a single network , i have configured 2 different pppoe server names for both, my network has no dhcp server configured.
The issue is sometimes clients from A isp mikrotik take long time to authenticate where as for B isp mikrotik clients can easily get authenticate without any issue,
Please suggest me a solution for this issue and do i need to do any configurations changes in the mikrotik ?
does configuring dhcp server will help ?
I am a beginner to these concepts , pls help me .
Please help me guys…!
I’m confused.
You want two ISPs on the same interface?
You want two ISPs on different interfaces?
You want users not be on a LAN?
You wan users to be on a LAN but not get DHCP IPs?
It is not clear to me because the brief scenario described is non-standard and thus more detail is required not less.
I am trying to use 2 isps in the same network with pppoe dial up setup
You have to post your config file.
