I am trying to reproduce the schema like in strongswan test net2net-gw, but with “moon” and “sun” behind NAT (see https://www.strongswan.org/testing/testresults/swanctl/net2net-gw/). So far CA configured, certs issued, mikrotik’s configured, i can establish tunnels and have SA set, but i can’t ping one site from another. Carol config :
connections {
gw-base {
local {
auth = pubkey
certs = carol.crt
id = carol
remote {
auth = pubkey
children {
net {
esp_proposals = aes128-sha1-modp2048,aes256-sha256-modp2048
version = 2
mobike = no
pools = pool-ipv4
gw-moon : connections.gw-base{
remote {
id = moon
children {
net {
local_ts = 192.168.3.0/24
remote_ts = 192.168.1.0/24
updown = /usr/libexec/strongswan/_updown iptables
gw-sun : connections.gw-base {
remote {
id = sun
children {
net {
local_ts = 192.168.1.0/24
remote_ts = 192.168.3.0/24
pools {
pool-ipv4 {
addrs = 192.168.99.0/24
here is “moon” mikrotik config local subnet 192.168.1.0/24 :
/ip ipsec mode-config
add name=ike2 responder=no
/ip ipsec policy group
add name=ike2
/ip ipsec profile
set [ find default=yes ] enc-algorithm=aes-128
add dh-group=modp2048 enc-algorithm=aes-128 name=ike2
/ip ipsec peer
add address=carol exchange-mode=ike2 name=ike2 profile=ike2
/ip ipsec proposal
add enc-algorithms=aes-128-cbc name=ike2 pfs-group=modp2048
/ip ipsec identity
add auth-method=digital-signature certificate=moon.p12_0 generate-policy=port-strict mode-config=ike2 notrack-chain=prerouting peer=ike2 policy-template-group=ike2
/ip ipsec policy
add dst-address=192.168.3.0/24 group=ike2 proposal=ike2 src-address=192.168.1.0/24 template=yes
/ip ipsec settings
set accounting=no
https://removalsfordoncaster.co.uk/is “sun” mikrotik config local subnet 192.168.3.0/24 :
add name=ike2
/ip ipsec profile
/ip ipsec peer
/ip ipsec proposal
/ip ipsec identity
add auth-method=digital-signature certificate=sun.p12_0 generate-policy=port-strict mode-config=ike2 notrack-chain=prerouting peer=ike2 policy-template-group=ike2
/ip ipsec policy
add dst-address=192.168.1.0/24 group=ike2 proposal=ike2 src-address=192.168.3.0/24 template=yes
/ip ipsec settings
set accounting=no
“carol” output for swanctl -l
gw-moon: #12, ESTABLISHED, IKEv2, 278ded8c94f60a25_i dc1ea6a863cbbc3f_r*
local ‘carol’ @ PUBLICIP[4500]
remote ‘moon’ @ NATIP[9860] [192.168.99.1]
AES_CBC-128/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_2048
established 1938s ago, rekeying in 11168s
net: #11, reqid 8, INSTALLED, TUNNEL-in-UDP, ESP:AES_CBC-128/HMAC_SHA1_96/MODP_2048
installed 498s ago, rekeying in 2840s, expires in 3462s
in cb0314bb, 0 bytes, 0 packets
out 0159b817, 0 bytes, 0 packets
local 192.168.3.0/24
remote 192.168.1.0/24
gw-sun: #11, ESTABLISHED, IKEv2, b972f69efe68b876_i 1c57914f302e627b_r*
remote ‘sun’ @ NATIP[4500] [192.168.99.2]
established 1962s ago, rekeying in 11975s
net: #10, reqid 7, INSTALLED, TUNNEL-in-UDP, ESP:AES_CBC-128/HMAC_SHA1_96/MODP_2048
installed 519s ago, rekeying in 2890s, expires in 3441s
in c3a515f5, 2856 bytes, 34 packets, 0s ago
out 0b5614c6, 0 bytes, 0 packets
local 192.168.1.0/24
remote 192.168.3.0/24
“carol” iptables have :
-A FORWARD -s 192.168.1.0/24 -d 192.168.3.0/24 -i eth0 -m policy --dir in --pol ipsec --reqid 8 --proto esp -j ACCEPT
-A FORWARD -s 192.168.3.0/24 -d 192.168.1.0/24 -o eth0 -m policy --dir out --pol ipsec --reqid 8 --proto esp -j ACCEPT
-A FORWARD -s 192.168.3.0/24 -d 192.168.1.0/24 -i eth0 -m policy --dir in --pol ipsec --reqid 7 --proto esp -j ACCEPT
-A FORWARD -s 192.168.1.0/24 -d 192.168.3.0/24 -o eth0 -m policy --dir out --pol ipsec --reqid 7 --proto esp -j ACCEPT
“carol” has sysctl
net.ipv4.ip_forward = 1
net.ipv4.conf.all.accept_redirects = 0
net.ipv4.conf.all.send_redirects = 0
“carol” tcpdump net 192.168.0.0/16 when i run ping from one of workstations 192.168.3.254 behind “sun” :
08:46:57.820968 IP 192.168.3.254 > 192.168.1.1: ICMP echo request, id 30901, seq 357, length 64
08:46:57.821075 IP PUBLICIP > 192.168.1.1: ICMP echo request, id 30901, seq 357, length 64
PUBLICIP = carols public internet ip
NATIP = sun & moon nat ip
whet i try to ping 192.168.1.1 from “sun” i see that packet counter for increases, but no reply, the same as if i ping 192.168.3.1 from “moon”. BUT if i disconnect “sun” and add virtual ip address 192.168.3.1 to carol ip addr add 192.168.3.1/24 dev eth0 ping from “moon” to 192.168.3.1 succeeds, but strange thing - i cant ping “moon” from carol…
Thank’s for any advice in advance ![]()
