I want to setup a network which has two subnets. I would like the following (I think):
router 1 - 192.168.1.0/24
dhcp for 192.168.1.0/24 and 192.168.2.0/24 (not on the config, I want this)
eth0 (dhcp 80.xxx.xxx.xxx) ------ (internet)
bridge (src nat for providing services to internet)
eth1 (dhcp 192.168.1.0/24) ------ eth2 router 2 - 192.168.2.0/24
eth2 (dhcp 192.168.1.0/24) ------ temp connection from dev pc (static dhcp 192.168.1.90)
eth0 ------ eth1 router 1
bridge
eth1 (dhcp 192.168.2.0/24) ------ eth2 router 2 - 192.168.1.0/24
eth2 (dhcp 192.168.2.0/24
I cant get the subnets to talk to each other, Im not sure if the bridges are required on router 2, I can ping router 1 from router 2 and vice verse but I can’t ping a machine from either subnet from either subnet.
I can ping both routers when connected in on either router 1 or 2 but this might be a false positive becuase I cant see an arp entry in my routing table…winbox can only see a single router when Im connected in on a single interface on my dev machine.
I want two subnets, with a cable modem, which has nat. I want both 192 networks to be able to see their source and destination addresses unchanged as they are within the same private network but Im having problems with the nat and bridge. Its a bit of a mess, but this is what I currently have. Its broken at the minute. Feel free to destroy and start simple and we can build it up.
Router 1 config export
add admin-mac=D4:CA:6D:xx:xx:xx auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=192.168.1.10-192.168.1.254
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add address=192.168.1.1/24 comment=defconf interface=bridge network=\
192.168.1.0
add address=192.168.2.1/24 interface=ether2 network=192.168.2.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.1 name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid log=yes
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
add check-gateway=ping distance=1 dst-address=192.168.2.0/24 gateway=\
192.168.2.1
/ip service
set www address=192.168.1.0/24
set winbox address=192.168.1.0/24
Router 2 config export
add admin-mac=D4:CA:6D:69:93:5E auto-mac=no comment=defconf name=bridge
add name=default-dhcp ranges=192.168.2.10-192.168.2.254
add add-arp=yes address-pool=default-dhcp disabled=no interface=bridge name=defconf
add address=192.168.2.1/24 comment=defconf interface=bridge network=192.168.2.0
add address=192.168.1.1/24 interface=ether1 network=192.168.1.0
/ip dhcp-server lease
add address=192.168.55.90 client-id=1:0:1f:c6:37:14:3d mac-address=00:1F:C6:37:14:3D server=defconf
add address=192.168.55.3 client-id=ff:b6:22:f:eb:0:2:0:0:ab:11:94:4f:76:6c:55:eb:84:59 mac-address=\
88:51:FB:7E:85:2F server=defconf
add address=192.168.2.0/24 comment=defconf gateway=192.168.2.1
/ip dns static
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=\
established,related
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add check-gateway=ping distance=1 dst-address=192.168.1.0/24 gateway=ether1
/system routerboard settings
set silent-boot=no
/tool mac-server
/tool mac-server mac-winbox
Thanks ![]()
twok
