Two mikrotiks in seria
we have two mikrotiks:
Internet peering IP: 88.85.x.2/29
Aveable IP classes: 80.x.157.0/24, 80.x.158.0/24, 88.85.x.0/24
So… I want to “add” another mikrotik behind this and want to “assing” 80.x.158.0/24 class to it.
How ti set up routing?
The “main” (the first one) mikrotik have IP 80.x.157.1
you detail what do you want behind your mikrotik do?
Mikrotik 1
WAN IP - 80.85.X.2/29
LAN IP - 80.X.157.1/24
default Route : gateway=80.85.x.1
Mikrotik 2 connected to mikrotik 1 LAN
WAN IP 80.X.157.2/24
LAN IP 80.X.158.1/24
default Route : gateway=80.X.157.1
Make sure that the IP Pool is routed thru your upstream ISP....
[quote="ashish"]Mikrotik 1
add action=masquerade chain=srcnat comment="" disabled=no src-address= 80.X.157.2
add action=masquerade chain=srcnat comment="" disabled=no src-address=80.X.158.0/24
Both MT are PPPoE servers connected to same Freeradius.
IP assigning is not problem, problem is how to “route” 80.x.158.0/24. Clients behind MT2 should get public IP (80.x.158.y)
I try to do that, but routing was problem (pppoe clients can not ping MT1)
I will try again later.
