Two more bugs in 2.9 Winbox
On filter rules page, select a chain other than All and then close Winbox.
When Winbox is re-opened the chain selected still shows the last selected chain but the main window shows all rules.
Also, if the Filter rules page opens as Winbox starts, the Chain select drop down box is too small until you select another page and then return.
Andrew
Thank you for your bugreport. It will be fixed in next version.
