Router A
Bridge IP: 172.25.25.25 (bridged ports 3-5)
Interface 1 - to dsl modem
IP Interface 2 - 172.16.16.10 (conected to interface 1 Router B)
DHCP Server: 172.25.25.0/24 (assigned to the bridge)
NAT: SRCNAT PPOE Interface
Router B
Bridge IP: 172.30.30.30 (bridged Porte 2-5)
IP Interface 1 - 172.16.16.16 (conected to interface 2 Router A)
DHCP Server: 172.30.30.0/24 (assigned to the bridge)
DNS 172.16.16.10 - 8.8.8.8
Configuration Router A
Route 0.0.0.0 — PPOE Interface
Route 172.30.30.0/24 — 172.16.16.16
Configuration Router B
Route 172.25.25.0/24 — 172.16.16.10
Route 0.0.0.0 —172.16.16.10
The problem, i dont have internet on router B with 172.30.30.x addresses.
Can you help me?
Router A
X Interface: 172.16.16.10
Router B
Can you help me?
route b needs a route
0.0.0.0/0 gateway 172.16.16.10
Anumrak
December 26, 2018, 6:34am
3
Do you realize that default route should be found at the host in broadcast domain?
@shiyiqiang08
Sory, i missed up to put on the post the default gateway of the router B, its made and still dont have internet?
can you ping 8.8.8.8 from route b?
if you can ,route set is ok
if not ,may be dns is not set correctly
Nope, the ping says destination net unreachable, but nslookup works fine
i update the configuration, i missed up some details that now are in the original post.
krafg
December 27, 2018, 9:59pm
8
Anyway on router B add a masquerade without specifing the interface.
Scrnat → Masquerade
Regards.
