Hi Team,
I’m new to MikroTiks. Could you please advise what will happen if the default routes are enabled on two separate PPPoE interface on MikroTik router?
Thanks!
Hi Team,
Thanks!
Simple failover will happen. Route distance that’s lower will become “primary” WAN and route distance that’s higher will become “secondary wan”.
That’s it.
If you have two last resort gateways, the gateway with larger IP address will be inactive … if I’m not mistaken and this is vice versa!
