two PPPoE links from ISP
Hi all,
i hawe RB750GL with
eth 4 ISP1 PPPoE connection
eth 5 ISP2 PPPoE connection
eth1 local lan 10.177.1.0/24
  • how to use both ISP links to duble the speed
    ty
did you get the PPPoE Links from only 1 ISP ?
Does the Provider Support MLPPP ?
then http://wiki.mikrotik.com/wiki/Manual:MLPPP_over_single_and_multiple_links will help you.
if not, you can only get the max speed of one Uplink per session.
Greets Peter
Have a look at the following link:
http://wiki.mikrotik.com/wiki/Manual:PCC
Hey all,
Here’s an interesting spin on this…
I’ve used the manual PPC to load balance across PPPoE links many times and it works great.
I recently came across another situation, where they have two (they would like three), PPPoE links from the SAME ISP. The issue here, is that despite each link having a unique static IP address on the CPE end, the provider end has a single common LNS / termination IP address.
That means that the gateway route for each routing mark is the SAME IP address, and the Mikrotik ends up favouring (defaulting) one the links, and not using the other link.
Any ideas on that?
Rgds,
Wazza
Put the interface to the route rule rather than the gateway IP address.
