Two PPPOE over different ethernet and modems ( ISSUE )
Hi All,
I have run into a issue with my mikrotik routerboard 750s. ( Where I am most likely the problem )
What I have setup is two different pppoe connections, which dial out to two different modems on seperate ports.
The issue I run into is that one PPPOE will almost freeze up if i can put it that way.
Its connected but traffic wont run over it.
Here is my config: ( I have disabled the PPPOE for now, to prevent any mishaps )
Interface:
set 0 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1600
mac-address=00:0C:42:F0:0F:F4 mtu=1500 name=ether1 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:F0:0F:F5
master-port=none mtu=1500 name=ether2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
“To 7.2” disabled=no full-duplex=yes l2mtu=1598 mac-address=
00:0C:42:F0:0F:F6 master-port=none mtu=1500 name=ether3 speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
“To 8.2” disabled=no full-duplex=yes l2mtu=1598 mac-address=
00:0C:42:F0:0F:F7 master-port=none mtu=1500 name=ether4 speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
LAN disabled=no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:F0:0F:F8
master-port=none mtu=1500 name=ether5 speed=100Mbps
/interface pppoe-client
add ac-name=“” add-default-route=no allow=pap,chap,mschap1,mschap2 comment=
“AFRI ACC” dial-on-demand=no disabled=no interface=ether3 max-mru=
1480 max-mtu=1480 mrru=disabled name=pppoe-out2 password=######
profile=default service-name=“” use-peer-dns=no user=
#####@######add ac-name=“” add-default-route=no allow=pap,chap,mschap1,mschap2 comment=
“LAN ACC” dial-on-demand=no disabled=yes interface=ether4 max-mru=
1480 max-mtu=1480 mrru=disabled name=pppoe-out1 password=######
Routes
add disabled=no distance=10 dst-address=0.0.0.0/0 gateway=pppoe-out2
routing-mark=main_route scope=30 target-scope=10
add disabled=no distance=20 dst-address=0.0.0.0/0 gateway=pppoe-out1
add disabled=no distance=10 dst-address=0.0.0.0/0 gateway=pppoe-out1
routing-mark=secon_route scope=30 target-scope=10
add disabled=no distance=20 dst-address=0.0.0.0/0 gateway=pppoe-out2
add disabled=no distance=30 dst-address=0.0.0.0/0 gateway=pppoe-out2 scope=30
target-scope=10
add disabled=no distance=1 dst-address=192.168.1.0/24 gateway=192.168.0.10
add disabled=no distance=1 dst-address=192.168.5.0/24 gateway=192.168.0.10
Mangle
/ip firewall mangle
add action=mark-connection chain=prerouting comment=“##### PPPOE”
disabled=no in-interface=pppoe-out2 new-connection-mark=main_con
passthrough=yes
add action=mark-connection chain=forward disabled=no in-interface=pppoe-out2
new-connection-mark=main_con passthrough=yes
add action=mark-routing chain=output connection-mark=main_con disabled=no
new-routing-mark=main_route passthrough=yes
add action=mark-routing chain=prerouting connection-mark=main_con disabled=no
in-interface=!pppoe-out2 new-routing-mark=main_route passthrough=yes
add action=mark-connection chain=prerouting comment=“##### PPPOE” disabled=
no in-interface=pppoe-out1 new-connection-mark=secon_con passthrough=yes
add action=mark-connection chain=forward disabled=no in-interface=pppoe-out1
add action=mark-routing chain=output connection-mark=secon_con disabled=no
new-routing-mark=secon_route passthrough=yes
add action=mark-routing chain=prerouting connection-mark=secon_con disabled=
no in-interface=!pppoe-out1 new-routing-mark=secon_route passthrough=yes
I am not sure what you are trying to do but I found this article to be helpful:
http://wiki.mikrotik.com/wiki/Policy_Base_Routing
I was able to get to PPPoE clients to run out the same interface using mangle rules. That could work.
