I’m the manager of a campgroup. We are using around 30 APs with Metal 2SHPn operating in 2.4Ghz band. Half of them are connected to the LAN, but in some remote places we need to use WDS to extend the LAN.
We need to increase the number of remote APs to extend the coverage in some areas and I would like to use a separate radio (5Ghz) to connects that’s remotes APs like ruckus or meraki does.
do you know if exist any equipment from mikrotik with dual radio? do you know if exist some routerboad that support it? do you know if exist third party equipment with routeros that support it?
Thanks for all,
