could anyone write some tips for configure two router os on rb 532 and 802.11a without nstream and with best possible encryption.rb 532 speed is 333 and speed with in two rb532 is now only about 20Mbps.
Is WDS ok? any other bridge mode? Must use ip routing for better performance?
any hints…?
I agree that MikroTik .PDF is misleading to say the least. My testing has largely only related to NStreme2 and while total aggregate throughput is close to what the .PDF shows you will not see anything more than 20-22Mbps FDX with a RB532. The board just doesn’thave the CPU power to manage more than that with the current NStreme2 code.
Oh, and to achieve 20-22Mbps FDX with NStreme2 on RB532 boards you will need to run v2.9rc9. Later OS versions included the current v2.9.4 have a problem with the NStreme2 interface just stop passing data under high loads requiring the interface to be disabled and then re-enabled.
Also note that if the framer-policy is used and you can’t transmit the data (link dies after few seconds of data transfered) you should lower the framer-limit to the size when the data is going through. Of if you can’t get good results, then don’t use the framer-policy, set it to ‘none’
We understand that people get different results when testing – and that is because there are a number of variables such as configuration settings, RouterOS version, wireless hardware, platform hardware, bugs, cables, interference, antennas, environment (lot of materials where signal bounce and cancel each other), and so on.
So if you don’t get the same results as us or others, you should try to address the issues of why this happens. But, don’t accuse us or others of misleading people on purpose. Life is much too short to work with people that start making accusations unreasonably. We will not assist, support, or sell to those that takes this path.
Hi uldis,
interesting result.
I’ve ordered 2 routerboards but after many post claiming low throughput of RB with Nstreme2 I’m getting little bit worried.
What type of traffic it was(UDP/TCP)?
It’s bridged or routed?
What is the avg latency you get over link when 50% loaded?
My goal is to set-up 20Mbit/full duplex TCP link with low latency ( >5ms).
Is it a dream or reality?
First, let me say there was no intention to disparage the MikroTik product and if that impression came across I apologize.
I think we are all saying the same thing here. 44Mbps is about all the RB532 can handle. Cut it up however you want, but 44Mbps is it. If it’s 21-22Mbps FDX or 45Mbps HDX the RB532 is still is only capable of about 40-45Mbps.
I would love to see an NSTreme2 configuration loaded on two RB532s passing more than 45Mbps aggregate throughput, but I just don’t see it happening. I posted several screenshots of BW test results testing from one 3GHz MT box to another 3GHz MT box across two RB532s running NStreme2. The results don’t lie unless I’ve configured the NStreme2 setup incorrectly.
The two RB532s are sitting side by side with rssi readings at a solid -60. The NStreme2 configuration is setup exactly as the MT example shows. Please provide me a NStreme2 configuration for the RB532 that will produce better than 21-21Mbps FDX payload capacity…I don’t believe one exists.
These two screenshots will show the latency you can expect with a fully loaded 20Mbps FDX RB532 link. I haven’t tried v2.9.5 yet, but plan to this weekend.
Apples and oranges. I am only refering to FDX links…NSTreme2. Under load a FDX link will always outperform a HDX link… this is important for VoIP applications etc…
Ok, now show us what the graph history looked like…my guess is it was all over the place jumping up and down. The snapshot you provided does not show any history. My test information shows latency over the link during the test and a history of solid & consistant 21-22Mbps FDX.
Sure, I could set the Rates to 54MB on my test setup as well, but links that jump all over the place from 45/30Mbps to 10/5Mbps and back are of no use to us. Many tests over and over demonstrate on the RB532 a 24MB Rate & NStreme2 setup is the most solid combination.
Solid consistant BW is what is required for our clients. If your RB532 test setup can show 5, 10, 15 minutes of sustained 45Mbps/30Mbps then you have something and I want a copy!
boards arrived, so I upgraded from installed 2.9.1 to 2.9.5
and the results are:
max UDP full duplex:
28.5/29Mbit/s
max TCP full duplex:
23/8
slow cpu on machines generating traffic
when changed RBs, it was the same, so I guess CPU was limiting
max TCP one-way
29Mbit/s
when passing limited traffic, FDX 25/25Mbit
latency was from 5 to 15ms
setup:
nstreme2 in bridge with ether1, freq1 5500, freq2 5700, no-turbo(it was the same with/without), CPU clock 330MHz, framing: none, signal -55, tested on desk, linked on 54Mbit
I have a question:
I played with RBs from friend and in bios, there was an option to overclock CPU to 399MHz, but on mine, there is max 330. they are from the same delivery,same price,look same
i want to try 399, it should increse the throughpt, cause the RBs CPU is limiting. any ideas how to do it??
It appears MT has fixed the NStreme lockup/crash problem as long as no Framer Policy is set. This is great news as now we’ll be able to run firmware newer than v2.9rc9 on NStreme2 links!
Although the higher Data rates are not as stable as the 24MB Data Rate they are much more symmetrical than previous versions and able to squeak out a few more Mbps.
Interesting. I believe the only two options on the RB532s I’ve checked are 266MHz & 333MHz. However, I do recall reading somewhere that MT had an optional (special order?) 400MHz RB532. Possibly your friend ended up with the optional CPU?
