Two rb1110ah2 connected with cable cat6, pause rx interface
Hi all,
i have two rb1100 connected with cable cat 6.
The problem is interface , it losted connection for 1 or 2 second each minute rx packet 0 but don’t have error packet or flap port.
In rx Stats or tx Stats, no error. Changed cable cat 6, changed more port but same problem.
Firmware versione 6.24
i think error negotiation port?
Hello post your settings, have you some ethers in a bridge?
Cetalfio
yes in bridge 2 port eth active and four ethernets disabled
i tried with and without autonegotion and all mode
10 Half Duplex/Full Duplex
100 Half Duplex / Full Duplex
1000 Half Duplex / Full Duplex
Same result.
Please paste here your interface configuration to understand your settings. If you want connect both RB1000s you don’t need to create any bridge.
Please read these wikis:
http://wiki.mikrotik.com/wiki/Manual:Interface/Ethernet
http://wiki.mikrotik.com/wiki/Manual:Interface/Bridge
cetalfio
i found error on secondary routerboard
“excessive late collisions link duplex mismatch”
Changed cable
Changed port
but same result and nothing error packet
